Reply 40 of 274, by awgamer
Athlon XP-M can be set from 3x to 24x and FSB down to 50 MHz, so 150 MHz(which should be around a p200 in performance) to 2.6-2.8 GHz avg OC(almost a64 4000+ equivalent), by year that covers from 96' to 04' and software settable: http://fab51.com/cpu/barton/athlon-e24.html At 150 Mhz I wonder what it would be equivalent to with the l1/l2 cache disabled, at 2ghz with l1 off it's already down to between a 486 dx2 and dx4, so 93'' year wise: Disabling cache on newer CPUs With the final touch of slowmo I'd bet it'd cover the whole dos range.
Reply 41 of 274, by gerwin
Sounds cool in theory. I never had an unlocked Athlon XP. But I did notice that on an Athlon XP with L1 cache disabled: SB Live! PCI soundblaster emulation will malfunction (stuttering sound). So only boards with ISA slots are suitable for DOS gaming, which are only found on the earliest Athlon Mainboards. These have questionable KT133 chipsets and limited CPU support. Also I read somewhere that the Athlon needs to be ran at 600MHz minimum.
Reply 42 of 274, by trodas
Blaaaaah! 😀 No disrespect to you, but the source is dead on WRONG:
320.64MHz AXP-M: http://valid.x86.fr/8cqmjb
215.47MHz Duron: http://valid.x86.fr/kfqjxs
And it is stable, at 310MHz I run Athlon for 3 days short of one MONTH, making lowest Aquamark score 2 up to date: http://hwbot.org/submission/2980283_
Maybe I can get to 1 with the Duron 😁 But that require month+++ time... Not exactly speedy, 🤣.
It is dangerous to be right in matters on which the established authorities are wrong. Voltaire
I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts... Hemingway
Reply 45 of 274, by gerwin
I am not unwilling to look into it. Do these processors support software multiplier switching?
Could you provide me the datasheets (and the page number) describing the CPU registers that are concerned?
Thanks for clearing that up.
Reply 46 of 274, by feipoa
Gerwin, https://archive.org/details/bitsavers_tiTI486 … eGuide_19799789
The chip also has software enable/disable for the L1 cache.
Attached below is an excerpt from the SXL reference guide on the code required to enable clock doubling for the SXL.
    86.15 KiB
Reply 47 of 274, by boxpressed
gerwin -- I just noticed this with my K6-3+ system (FIC VA-503+). I have a Vortex 2 in the system that I use for its wavetable header in DOS. When I load the DOS driver, AU30DOS.COM, the system hangs after I start SETMUL. If I don't load the driver, everything works normally.
Reply 48 of 274, by gerwin
Noticed a similar thing when using "Throttle for ALi Aladdin 5 Socket 7 boards":
I noticed a nasty lockup when using 'SetMul' to toggle the AMD K6+ multiplier while
Trottle was enabled. Using SetMul prior to, and after closing Throttle is fine.
I will investigate..
Reply 49 of 274, by lvader
After an aborted attempt of building a socket 7 K6 III+ system (CPU correctly detected but the system keep rebooting instead of booting the OS) I've decided to try VIA C3 as it looks like it gives me even more flexibility. I've found a suitable mobo with 3 ISA slots and I have a few CPUs on the way, an Ezra 800 Mhz, Ezra-T 1 Ghz and a Nehemiah 1.2 GHz. Would I be right in saying the Ezra-t would be the one to go for for the greatest flexibility at the lower end of performance? Also is the multiplier locked to it's rated speed (i.e.133 x 7.5) or can I attempt to go higher (i.e. overclock). Presuming the multiplier isn't locked, With I cache disabled is it likely to overclock more than if all caches enabled (i.e. full speed) and give me more working multiplier options?
Also I'm I right in saying the main benefit of Ezra-t vs a regular Ezra is that the FSB isn't locked?
Thanks
Jeff
Reply 50 of 274, by gerwin
For VIA C3s: only the startup multiplier is fixed (though there are ways..), yet through the power saving interface all multipliers described in the SetMul documentation are available. Regardless of FSB. The catch is that the total amount of MHz cannot be much more then the original rating, just because these processors overclock poorly.
The Ezra-T is indeed the most flexible in 486 speed emulation. On the other hand; When not downclocking the Nehemiah is about twice as fast as the Ezra-T, and I expect the Nehemiah to slow down more extremely into the 386 range.
Reply 52 of 274, by j^aws
With appropriate slotkets that can overvolt, the Ezra-T can overclock into the 1300-1400 MHz range. Stock is around 1.4v, and around 1.65v, these CPUs overclock with adequate cooling. Still significantly slower than Nehemiahs, but far more flexible in the right board.
Reply 53 of 274, by gdjacobs
Being Cyrix based, do MediaGX Geode processors support soft multiplier configuration?
Reply 55 of 274, by PhilsComputerLab
lvader wrote:
After an aborted attempt of building a socket 7 K6 III+ system (CPU correctly detected but the system keep rebooting instead of […]
Thanks
Jeff
Keen to hear how you go with all of this. What motherboard did you end up going for?
YouTube, Facebook, Website
Reply 57 of 274, by feipoa
ibm5155 wrote:
Does it work with the cyrix Gxm?
feipoa wrote:
I recall looking into this at one point and the answer was no.
I think the GXm needs to see the binary values placed on CLKMODE pins to set the multiplier.
Reply 58 of 274, by ibm5155
my notebook can change teh clock speed from 200MHz to 175MHz, also overe Windows there's a tool that can low the performance to 50% (idk if it's downclocking the processor or doing another trick)
I really need something for testing this netbook D: (is there some native Windows 98 tool for checking the processor clock? so I could confirm if the processor is doing downclock or not)
EDIT: but maybe that's something special that only happens with my board
Here're some pictures that I found from the inside of my netbook
https://scontent.fcwb1-1.fna.fbcdn.net/t31.0- … 951716520_o.jpg
https://scontent.fcwb1-1.fna.fbcdn.net/t31.0- … 169002610_o.jpg
Reply 59 of 274, by feipoa
I question whether your notebook is really downclocking the CPU. The GXm's I've used and have read about all have a 30 MHz or 33.3 MHz FSB and 175 MHz is not an integer multiple of 30 or 33.3. The GXm only has integer multipliers.
