First post, by x86++
x86++
Offline
Attached two replacement wav files** for Action Quake 2 v1.52. In the case where there are in-game errors related to these files, then copy the replacement files to AQ2 PAK1.PAK (under /sounds/weapons/). A tool that does PAK file handling is "pakscape".
The shellhit1.wav file may not be necessary if "shell casings" is turned off in autoexec.cfg.
** Original link to AQ2 sound packs:
http://www.oocities.org/timessquare/bunker/9606/downaq2.htm
