Reply 500 of 2484, by Falcosoft
- l33t
It's not easy to tell how good it works because those Konami files were made for SC-88Pro
Yes, but very few midi files were made specially for Bassmidi/soundfonts, yet GM/GS files produce the best results with soundfonts 😀
The MIDI Channels Viewer only displays the first 16 channels...
I have written that all ports are combined so on channels viewer you actually can see all ports/channels together.
but the Event Debugger lists all 32 channels
I don't see 32 channels there, but 35 tracks 😀
I don't think dual port midi files are different from standard 1 port files that use more tracks than channels( and these are common). So there are no true 32 channels but more than 1 track that use the same channel from the available 16. But as I said it's not specific for these dual port midi files, many standard midi files use more than one track for one channel. I think the only difference is the port preference meta event. If you can please check that your other dual port files also use these meta events on the tracks. In the event debugger select Filters->All Non-Channel Events. At the beginning of each track you should see a 'Port pref.' meta event (if dual-port files work the way as I think).
Edit:
Or you can send me some more files for checking.
I have also re-uploaded 4.9 test since seeking was buggy (hanging notes on 16+ channels)
