Reply 660 of 2513, by Falcosoft
- l33t
version 5.3 of FSMP is released. The test zips are no longer available.
http://falcosoft.hu/softwares.html#midiplayer
version 5.3
1. Added Folder.syx support. It works similar to Folder.sf2. If you put a Folder.syx file into a folder all the midi files in that folder will load the syx file before playing.
2. To support the Folder.syx feature a new option called 'Save SysEx data from Midi' can be found in the File menu of Event Viewer/Debugger. With the help of this you can save/extract the initialization SysEx data from midi files to a syx file that can be renamed and used as a Folder.syx file.
3. Added support for native WASAPI audio output on Windows Vista/7/8/10 (it applies to both Bassmidi and VSTi output modes). This setting is available in the Bass part of the Device Settings dialog. With WASAPI you can achieve lower latency output that can be useful if you use FSMP also as a real time soft synth.
4. Added 'Channels' compatibility option to support Microsoft specific channel layouts (explicit Basic/Extended/GM and auto mode). More info:
5. Added fast loop option to Loop Settings dialog. If enabled FSMP does not send messages to assure correct controller, program etc. states at the loop start point so it is much faster but requires properly programmed loop points. It can be mostly useful in case of slower hardware.
6. Improved Event Viewer: filtered event count display, F3 to skip to next filtered event, display meta sequencer data, display GM program names.
7. Other minor fixes and enhancements.
