Reply 180 of 319, by gerwin
- l33t
SetMul v1.24 is up:
- Improved accuracy of RDTSC clockspeed measurements.
- Added alternate clockspeed measurement of older processors, like 386/486/Cx5x86.
- More consistent message colors and CPU information display.
- Cleaned up debug output mode, which is triggered with parameter DBG.
- Added option to disable clockspeed measurements with parameter CMD.
- Retain some CPU information functionality within Windows NT based OS.
- Overhauled CPU identification with proper use of extended family and model.
Earlier the Cyrix 5x86 was found to respond to its multiplier jumper/pin while running.
It seems this also goes for later Cyrix Processors such as the MII. This made it possible to switch to 1.0x and 60MHz and work at that speed, even though the system does not want to boot with that setting.
Care has to be taken to close/open the jumper as quick and smooth as possible, otherwise the system will lock up. I think adding a mechanical switch for this job is the best solution.
