Hey Peixoto,
Wonderful wonderful work on the patch for various game. I was trying to get onimusha work but I ended up having very frustrating results which later on made me discover that of why such thing is happening. I believe the coding needs to be re-approached.
I discovered many things of why I get such strange graphical result like this:
![unknown.png](https://cdn.discordapp.com/attachments/454347995744305165/721245812931428403/unknown.png)
![unknown.png](https://cdn.discordapp.com/attachments/454347995744305165/721245831524646942/unknown.png)
First of all, the way this port is heavily coded to detect what display using rather than GPU. So the display part is handled entirely by the iCPU, which easily makes sense on a desktop, it's just plugging the cables from GPU <--> Monitor instead of CPU (iGPU) <--> Monitor.
![unknown.png](https://cdn.discordapp.com/attachments/500442728925233152/722529884089352292/unknown.png)
![unknown.png](https://cdn.discordapp.com/attachments/500442728925233152/722534172383641650/unknown.png)
The problem with the laptop is that we can't do that because the output of the Intel GPU is feeding the Display.
![unknown.png](https://cdn.discordapp.com/attachments/500442728925233152/722530227921616896/unknown.png)
I tried most possible solutions through NIVIDIA control panel and there is no luck at all. Is there any possible chance that you could work on this and patch ? I am trying pretty much making this port favourable to everyone due to one of the only ports that includes cut-scene skip. So the speedrun community can finally run the game without any additional hassle.
I talked with people that I worked with to make this patch work:
- When the game installed fresh without any patch it worked through fortinbras but encountered an issue that drops fps heavily along with graphical bugs.
- After using official normal patches which is 1.01 and 1.02, the game worked well FPS issues with souls on screen gone. graphical bugs like vanishing body parts are gone too up until fortinbras crash.
- After the attempt of using your patch, they couldn't go through starting a new game and it just sits at a blackscreen. Furthermore, just straight crashes instead of launching.
Is it also possible if we could keep in touch together through Discord ? So we can keep the communication pretty much frequent ?
