Reply 1140 of 1815, by Falcosoft
- l33t
kolderman wrote on 2020-12-14, 03:06:HI Falconsoft, not sure if this has been reported before, but playing a midi track for many hours will eventually crash the X-Fi and/or computer with Win7. Not sure if a crash in the VSTI plugin or Midi Player.
No, it has not been reported and I do not think it is a general problem. I have not met this problem myself so far, yet I have used the player for many hours even on Win7.
So overall I do not think the player itself can crash the system but it is easy to check:
Play the same Midi for the same time using a standard Midi output port like MS GM/GS Soft synth.
Then you can also try Bassmidi with a soundfont and also a different VSTi plugin.
