keenmaster486 wrote on 2021-04-12, 21:09:log in to Vogons using WebOne? It just redirects to the login page
Yes, this is a known bug. But currently I still can't find why the log in does not work. Also vk.com login feature does not working (similarly, but it also saying that the password is incorrect). Very interesting and difficult bug.
aha2940 wrote on 2021-04-12, 20:50:1. I downloaded the source file for version 0.10.7 in tar.gz format, however I found no source code inside, only a couple big windows binaries (ffmpeg.exe and convert.exe) along with other smaller files. Can a proper source code release file be made?
Hmm... It is a correct C# project.
There is currently no makefile, but it can be written by analogy with build.bat (which is using on Windows with Visual Studio 2019 or .NET Core SDK). All dotnet commands from build.bat are working on Linux with .NET SDK too, the difference only in directory cleanup stuff (e.g. deltree/rm -rf).
aha2940 wrote on 2021-04-12, 20:50:2. I also cannot find the SPEC files used to build the RPM files. It would be cool if you could release them.
Deb/Rpm packages are building via dotnet-packaging add-on for .NET Core, and all package options are stored in WebOne.csproj file.
aha2940 wrote on 2021-04-12, 20:50:3. I noticed the Linux release is not very consistent in naming: some things are named WebOne and others are named webone. That does not matter for Windows, but since Linux is case sensitive, that makes a difference. I'd like to suggest for everything on Linux to be renamed webone (all lowercase) since that makes things more consistent with everything else on the OS.
Yes, it will be a good thing. Also I'm planning in the next release, v0.11.0, replace /etc/WebOne/webone.conf file with /etc/webone.conf base file /etc/webone.conf.d/ directory with all overridings for the configuration. Because all updates are overwritting the current single config file and it needs to be re-edited by hand every time.
2×8080, 2×Soviet ZX-Speccy, 1×MacIIsi, 1×086, 1×286, 3×386DX, 1×386SX, 2×486, 1×P54C, 8×P55C, 7×Slot1, 5×S370, 1×SlotA, 2×S462, ∞×Modern.
