Reply 561 of 781, by mrau
PhilsComputerLab wrote:
Haven't updated here in a while...
bad bad boy you 😀 most probably subscribe your thing anyway.
say, please, is that stick thingy able to run DOS? or is it a windows retro thingy only?
the newer one i'm watching right now;
Reply 562 of 781, by PhilsComputerLab
I'd go with DOSBox to be honest. You wouldn't even have a sound card under pure DOS, maybe not even a mouse and who knows what else doesn't work properly? Stretched image?
YouTube, Facebook, Website
Reply 563 of 781, by badmojo
You've been quiet Phil, what's going on? Got yourself a girlfriend?? 😊
Reply 564 of 781, by PhilsComputerLab
🤣 Just focusing a bit more on my YouTube.
Reply 566 of 781, by maverick85
searched ebay, cant find anything similar to what you have in the video Phil. any help?
ASRock 98
Win98SE Desktop
ASRock
Intel Core 2 Duo E8400 3.0GHz
1 x 512MB 667 MHz DDR2
Soundblaster SB0100 + Altec Lansing ADA885
ATi Radeon X800XT 256MB GDDR3
1 x SATA 120GB HDD
1 x SATA DVD-RW
Reply 567 of 781, by PhilsComputerLab
Type "SD IDE adapter"
Reply 568 of 781, by melbar
Nice video, Phil.
Comparing your results of tested VGA cards, i come across over your selected resolutions for this test.
All values are shown in 32bit... and you compare also with the V3-3500. Isn't it (from 3dfx products), that V4 and V5 only are able to render 32bit... 😊
Maybe there's a remark, hint or a (*) useful that you've tested it with 16bit?
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 569 of 781, by PhilsComputerLab
Yes I've explained this in the previous video(s) I believe. But most know that Voodoo 3 was about speed and sacrificed a bit of image quality.
Reply 571 of 781, by Tetrium
Nvidia RIVA 128: Gaming on a 20 year old Nvidia card: https://youtu.be/vige3LUVT5M
Interesting! Learned a couple new things 😀
I never used a Riva128. Is TNT1 a lot different btw?
My retro rigs (old topic)
Report spammers here!
Reply 572 of 781, by maverick85
nope, most results were for compact flash
ASRock 98
Win98SE Desktop
ASRock
1 x SATA 120GB HDD
1 x SATA DVD-RW
Reply 573 of 781, by elianda
Depends what you mean, but TNT is DirectX6, quoting from Wikipedia "It added a second pixel pipeline, practically doubling rendering speed, and used considerably faster memory. [...] it also added support for a 32-bit (truecolor) pixel format, 24-bit Z-buffer in 3D mode, an 8-bit stencil buffer and support for 1024×1024 pixels textures. Improved texture filtering techniques, partially assisted by newly added trilinear filtering, dramatically improved image quality compared to the TNT's predecessor."
Youtube Channel
Reply 574 of 781, by PhilsComputerLab
This is for anyone complaining about retro parts being to expensive.
> It doesn't have to be Asus, 3dfx and Co
Because a lot of people complained that I always use parts that cost a fortune I made a 3 part series building the cheapest Windows 98 Gaming PC possible.
In the videos I look for parts on ebay and we piece together a Socket 754 board (NIB for 12 bucks!), Sempron 2800+, 512 MB, 80 GB SATA and a Radeon 9550 AGP card. Onboard sound will do.
The first video shows the build. The second video has benchmarks of the onboard GPU as well as the Radeon. HDD performance, BIOS options, drivers and more are discussed. The last video is all about the game, showcasing games from 1996 to 2001 with surprising results.
Part 1: https://youtu.be/5OFaWs136eY
Part 2: https://youtu.be/bYkv8zCfpuM
Part 3: https://youtu.be/zNMeH7G1KW8
Bottom line: There is so much hardware out there that you can get for little money, or even free if you are willing to think outside the box and not fixate on certain parts.
Reply 575 of 781, by PhilsComputerLab
What's retro gaming like on a $79 tablet PC?
https://youtu.be/ZNF1tXDNlT4
I was actually amazed at the value. Highlight is the 8" IPS screen with 1920 x 1200 resolution. This has some benefits:
1600 x 1200 4:3 resolution pixel perfect
800 x 600 resolution pixel perfect
DOSBox / ScummVM 320 x 200 games scale pixel perfect
The Z8300 has a much stronger GPU compared to the previous version.
The screen has awesome black levels, great viewing angles.
What's not so good:
Couldn't find a way to charge and use USB accessories at the same time
Storage space not enough, had to use a Micro SD card
Reply 576 of 781, by gdjacobs
What's retro gaming like on a $79 tablet PC? […]
What's not so good:
There are USB power injectors that allow simultaneous use of OTG.
Reply 577 of 781, by PhilsComputerLab
I bought such a cable, but not all devices support it apparently.
My next step will be trying to wipe the partitions (Android) to free up some space. But will take an image of the disk first.
Reply 578 of 781, by gdjacobs
Yes, the OTG driver has to properly sense the configuration.
Reply 579 of 781, by Great Hierophant
What's not so good:
1920x1200 - The Resolution of Champions™
