First post, by DosFreak
- l33t++
7-Zip is open source software. Most of the source code is under the GNU LGPL license. The unRAR code is under a mixed license: G […]
7-Zip is open source software. Most of the source code is under the GNU LGPL license. The unRAR code is under a mixed license: GNU LGPL + unRAR restrictions. Check license information here: 7-Zip license.
You can use 7-Zip on any computer, including a computer in a commercial organization. You don't need to register or pay for 7-Zip.
The main features of 7-Zip* High compression ratio in new 7z format with LZMA compression
* Supported formats:
o Packing / unpacking: 7z, XZ, BZIP2, GZIP, TAR, ZIP and WIM
o Unpacking only: ARJ, CAB, CHM, CPIO, CramFS, DEB, DMG, FAT, HFS, ISO, LZH, LZMA, MBR, MSI, NSIS, NTFS, RAR, RPM, SquashFS, UDF, VHD, WIM, XAR and Z.
* For ZIP and GZIP formats, 7-Zip provides a compression ratio that is 2-10 % better than the ratio provided by PKZip and WinZip
* Strong AES-256 encryption in 7z and ZIP formats
* Self-extracting capability for 7z format
* Integration with Windows Shell
* Powerful File Manager
* Powerful command line version
* Plugin for FAR Manager
* Localizations for 79 languages
9.20 2010-11-18
- Some bugs were fixed.
