Reply 180 of 280, by DracoNihil
rfnagel contacted me on Steam, there's a particular commit of code that I suspect might be causing the issue. Would need people to test it out though.
The files in rfnagel's post are the same ones I am using right now. So everything is good for nor save for this mystery.
― Κυνικός Δράκων
Reply 181 of 280, by ElectricMonk
Is there a plan for a linux version of BASSMIDI or MUNT? I installed Linux Mint 17 in Virtualbox, for integration in a GNS3 network sim, and I'm actually kinda grooving on it. I might either dualboot my next laptop, or replace Windows whatever with Mint. I'd love to be able to use both utilities and my soundfont collections on linux.
Reply 182 of 280, by kode54
Sorry about that guys, that line should read as:
exlen = ( dwParam2 >= 0xF8 && dwParam2 <= 0xFF ) ? 1 : (( dwParam2 == 0xC0 || dwParam2 == 0xD0 ) ? 2 : 3);
There's also this for Linux, but no telling if it works 100% correctly for everyone, and it's just a bit of a pain to set up anyway. Locating the libbassflac and libbasswv libraries may either require hardcoding their paths, or installing them to /usr/lib or /usr/local/lib first.
MUNT should be portable to that same user mode driver, which I basically stole off some other FOSS project that implemented a user mode ALSA MIDI driver. It currently implements four ports for the life of the process, and it will shut down and reload the specified soundfont or sflist whenever it receives SIGHUP, and will hopefully terminate cleanly when it receives SIGTERM.
Reply 184 of 280, by DracoNihil
Thanks for the quick fix kode54! It's working just fine now.
― Κυνικός Δράκων
Reply 185 of 280, by F2bnp
I seem to have the same problem as Stereoprism. I get a lot of crackling sound when attempting to play MIDI music using BASSMIDI. This happens with WinAMP and DOSBox (I noticed it first when playing a game), but not with Foobar2000 and it's own BASSMIDI plugin!
This is all under Windows 8, if it helps in any way. Tried buffer sizes, but to no avail.
Reply 186 of 280, by DracoNihil
Another person I know using windows 8 is having the same crackling issue.
My only suggestion is to downgrade to 7, but obviously Windows 8 is doing something SERIOUSLY STUPID with audio handles...
― Κυνικός Δράκων
Reply 188 of 280, by PhilsComputerLab
I am having trouble finding the latest version. There are a lot of links on the site, some not working.
YouTube, Facebook, Website
Reply 189 of 280, by HunterZ
There were 3 sites where it used to be: Kode54, rfnagel, and mudlord. Terribly confusing.
At this point, only kode54 seems to be working:
http://www.kode54.net/bassmididrv/
Reply 190 of 280, by rfnagel
HunterZ wrote:
At this point, only kode54 seems to be working: http://www.kode54.net/bassmididrv/
FYI, Kode54's site will always have the newest version.
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 191 of 280, by mudlord
uh huh, and http://www.mudlord.info/products.html has a link which points to kode54's page. How the hell is that confusing?
oh, and I think I worked out a Windows 8.1 fix. Not sure why Xaudio2 is so fucked, had much better luck forcing dsound and increasing default buffer sizes.
Reply 192 of 280, by HunterZ
Because they all look the same, but some of the links on some of them point to different places, including places that no longer work.
Reply 193 of 280, by PhilsComputerLab
I also had trouble navigating that site 😊
I'm using this MIDI device now: http://coolsoft.altervista.org/en/virtualmidisynth
It works very well under Windows 8.1 and seems to get updated quite recently. It also puts itself as the default MIDI device which is quite interesting.
Reply 195 of 280, by HunterZ
I use virtualmidisynth almost exclusively as a MIDI device picker so that I can set BASSMIDIDrv or Munt as my default synth 😀
Strangely, VMS installs a newer bass.dll and older bassmidi.dll than BMD.
Reply 197 of 280, by mudlord
Uploaded WIP Windows 8 fix.
32bit driver.
Pondering rewriting some stuff for Win8 anyway. Seems to work in my Windows 7 VM. The WIP driver is crackly in Windows XP, then again for me, in a XP VM the original driver is too.
    bassmididrv.rar
    56.53 KiB
    117 downloads
Reply 198 of 280, by rfnagel
(re: the previously mentioned WeedsGM4)
I STILL haven't got off of my arse and compiled/added my previously mentioned WeedsGM4 Update to my Weeds General MIDI SoundFont v3.0. But, that being said, I went ahead and uploaded the separate updated soundfont to my web space.
This update ("WeedsGM4 Update.sf2") can be "stacked" on top of "WeedsGM3.sf2", hence anything contained in the update will supersede any matching preset in "WeedsGM3.sf2" 😀
Here is what's updated in "WeedsGM4 Update.sf2":
Bank:Preset = Instrument
001:018 = B3 Leslie Organ
001:025 = Mandolin
002:025 = Mandolin Tremolo
000:043 = Solo ContraBass
000:047 = 8MBGM Timpani
001:105 = Kay KBJ100 Banjo
001:109 = Highland Bagpipes
002:109 = Bagpipes Ensemble
Also included in the ZIP are some newer sample MIDI files to test out the "WeedsGM3.sf2" and "WeedsGM4 Update.sf2" with, as well as an instrument definition file ("WeedsGM4.ins") for Cakewalk Professional.
Anyhow, snag the ZIP from here -> http://jasonwilliams400com.startlogic.com/sno … sGM4_Update.zip 😀
As previously mentioned, ensure that you stack "WeedsGM4 Update.sf2" on top of "WeedsGM3.sf2" to take advantage of the update.
Rich ¥Weeds¥ Nagel
