Hey,
I didn't know where else to ask this, but I have a friend who's been using your Munt VSTi plugin, and his MIDI keyboard doesn't have any way to do Program Change messages. If public source code existed for the plugin, I'd do it myself, but I wanted to know either:
a) If I could have a copy of the source code for the Munt VSTi so I could tweak it for him
or, barring that:
b) If you could add something to the GUI for the Munt VSTi to allow changing the instruments for different channels.
Thanks for the stuff you've done, in any case.
I don't really need that functionality myself, since I run Linux and just use ALSA with a PCM loopback device to handle everything (and an Atari ST emulator to make patches). But he'd really appreciate it, from the Windows environment which doesn't provide as much in the way of handy loopback devices and a VST-centric setup.
IBM PC: AT&T 6300; Gateway E-3200 with Voodoo3 (AGP), ES1688 sound, and SB Live; Thinkpad 760EL.
PC-9801: NEC PC-9821 Ce2, Epson PC-486GR.
Macintosh: PowerBook G4, Macintosh Centris 650.
Commodore: A500 (NTSC, USA), A500 (PAL, Germany), VIC-20, C64.
