First post, by vvbee
- Oldbie
PATH_BENCH is a simple path tracing benchmark for DOS. Renders a basic scene and outputs the time it took to do so. Requires a math copro and can be quite slow on pre-pentiums.
What's path tracing? Like ray tracing, but better and more computationally demanding. Heavy on floating-point math. Look it up on the wiki.
Results, in order of render speed:
CPU SECONDS CONTRIBUTED_BY NOTESXeon E3-1230 v3............<1...........vvbee....................In Linux (native port).Athlon 64 X2 5050e.........4............vvbee....................Athlon XP 2200+............7............vvbee....................Celeron 2.4................9............vvbee....................Atom N270..................37...........vvbee....................K6-2/300...................47...........vvbee....................Pentium/90.................165..........vvbee....................486DX2/66..................361..........vladstamate..............K6-2/300 no L1.............419..........vvbee....................Athlon XP 2200+ no L1......670..........vvbee....................Athlon XP 2200+ no L1/L2...671..........vvbee....................K6-2/300 no L1/L2..........1351.........vvbee....................386DX/40...................4758.........vladstamate..............With copro.
Timing should be correct on real hardware, but not guaranteed in e.g. dosbox (check your settings). Designed for square pixels (16:10 ratio).
