Fasttracker 2.12 for MS-DOS
Reply 60 of 130, by 8bitbubsy
SaxxonPike wrote on 2020-05-27, 14:08:
Thank you so much for updating FastTracker II! This was a very unexpected project. I recall learning how to use trackers in the late 90s with version 2.04. It was my introduction to music altogether. To see any updates since 2.09 is like a dream come true. I can't wait to return home and try this out.
You might want to check out my accurate FT2 clone for modern OSes too: https://16-bits.org/ft2.php
486:
- Motherboard: "SIS 486G 3.3/5V Ver:E" w/ 256kB L2 cache
- CPU: Intel 486DX2 66MHz
- RAM: 16MB 60ns FPM
- VGA: S3 Vision864 2MB VLB
- Audio: SB16 CT2800 (real OPL3)
- ISA PS/2 mouse card
- ISA USB
- MS-DOS 6.22 + WfW 3.11
Reply 61 of 130, by digger
8bitbubsy wrote on 2018-11-07, 16:16:
Because it's not trivial to implement. We're talking low-level hardware interraction through x86 assembler here. I'm not the correct dude for implementing new big things like that.
Perhaps this could help: I've dusted off the source code of a simple WAV player for AC'97 sound devices as found in motherboards and laptops with Intel ICH, ICH0 and ICH2 southbridges. It was initially written and released by Jeff Leyda. I'm currently trying to improve it to support later ICHx revisions up to ICH7 as well.
It's DOS assembly code that's fairly easy to follow. It also helps that it's well documented.
Perhaps you could use it as a basis to add ICHx AC'97 support to Fast Tracker II for DOS as well?
See topic Re: Can anybody with AC'97 audio please help me test a DOS player? 😊
Or would adding support for new sound devices really be too herculean?
How about doing so through a more high-level API, such as VBE/AI, which works with int 10h calls and abstracts away all the tedious DMA stuff?
At any rate, thanks for continuing to support Fast Tracker II. Even though I'm not much of a composer, I remember playing with it back in the day and marvelling at the (for the time) fancy UI and smooth performance. It's one of the sleekest non-game DOS applications I've ever experienced.
Reply 62 of 130, by 8bitbubsy
That's way too much code to go through for supporting just some AC'97 devices, and FT2 is running in 16-bit protected mode. Implementing this wouldn't be trivial for someone like me, and unfortunately I'm not allowed to share the FT2 source code with other people.
486:
- ISA USB
Reply 63 of 130, by traffkin
8bitbubsy wrote on 2020-05-27, 18:47:
that's real pity, as i've found a guy who knows the subject very well and he could fix all the stuff and add a lot, for example acceptable midi implementation...
Reply 65 of 130, by 8bitbubsy
traffkin wrote on 2020-06-18, 16:02:
is there any chance to have a midi clock in/out on the FT2?.. would be just awesome...
Again, I don't really know MIDI nor the low-level MIDI stuff in FT2. I am not the right person to add these new low-level things. Sorry...
486:
- ISA USB
Reply 67 of 130, by 8bitbubsy
I'd like to try and fix it instead of removing the feature. Does anyone know in what FT2 version it stopped working when you select LPT1+LPT2 @ stereo? I can't test it myself because I have no PC with a second parallel port, thus selecting LPT2 or LPT1+LPT2 will just revert to LPT1.
If someone would like to find out for me, I'd be happy. Here's a collection of all the FT2 releases I have found so far: https://16-bits.org/ft2
(the only version I'm missing is FT2.02 (and possibly FT2.00) . If someone has it, let me know!)
486:
- ISA USB
Reply 68 of 130, by thierry
What if I could try is that it is very slow, it sounds bad and the sound is cut, I use a 386dx40mhz, 8mb ram, GUS Classic, I tried removing the EMM386 but with no luck, today I am going to test with other configurations.
Reply 69 of 130, by 8bitbubsy
thierry wrote on 2020-07-10, 15:09:
Does FT2.08 work better? https://16-bits.org/ft2/FT208.ZIP
486:
- ISA USB
Reply 70 of 130, by thierry
8bitbubsy wrote on 2020-07-10, 15:11:
i try it in a few moments
Reply 71 of 130, by thierry
I have it ! , it detects the wrong IRQ and DMA of my GUS Classic, my configuration is IRQ 7 DMA 3, for some reason it does not let me change it, in version 2.08 I can change the DMA and IRQ of the Sound Blaster only , in version 2.11 it does not let me change or GUS or SBPro 2.0 , Is there a command line to specify IRQ and DMA?
Reply 73 of 130, by 8bitbubsy
I don't know how to fix that problem. It detects the correct IRQ/DMA settings with DOSBox and GUS, at least. Did you properly install the GUS DOS drivers?
486:
- ISA USB
Reply 74 of 130, by thierry
8bitbubsy wrote on 2020-07-11, 08:12:
Yes , Gus drivers and init setup works fine , im use another player to test ( Inertia Player ) and detect the config okk , games works fine too , im try to install another new drivers and new init and try again
Reply 75 of 130, by thierry
Works ! , I was able to install the GUS 4.11 Drivers and I replaced the Ultrinit 2.28 by 2.28a and of course all the drivers, it is not a good idea to have the GUS drivers without updating, I just saw that I had my old drivers, I'm going to take it as a reference to install my 486 , but everything is perfect now , Thank you!
Reply 76 of 130, by 8bitbubsy
Nice! 😀
486:
- ISA USB
Reply 79 of 130, by drastikterror
Hello!
I was thinking about the possibility to implement a generic midi mpu-401 driver to make Ft2 work with external devices, in a way like Impulse tracker did with the command "it /s19 /a330"
Thank you!
