First post, by Stiletto
Back on October 1st, Aaru 5.3.0 was released.
It's intended to be a Long Term Support release, supported until the next LTS version is released.
Website(s):
https://aaru.app/ (it's a new redesign and currently a little broken)
https://github.com/aaru-dps/aaru/
Download:
https://github.com/aaru-dps/Aaru/releases/tag/v5.3.0
What's new: https://github.com/aaru-dps/Aaru/blob/devel/Changelog.md
Blog post: https://blog.claunia.com/aaru-long-term-release/
See my commentary here on the project: Re: What is the best way to make floppy and CD images in regards to file integrity?
They are in need of testers! So download, kick the tires, and head over to their varied support systems (Github, Discord, etc.) if you have problems 😀
It's pretty much command-line based, but there's a basic frontend called SabreTools Media Preservation Frontend (MPF) if you need it: https://github.com/SabreTools/MPF
What is Aaru?
Aaru Data Preservation Suite is a fully-featured software package to preserve all storage media from the very old to the cutting edge, as well as to give detailed information about any supported image file (whether from Aaru or not) and to extract the files from those images.
Aaru DPS includes:
• Aaru
• The main software that does all the heavy lifting, including dumping and extraction.
• Aaru Remote
• A slim application that allows Aaru to dump media or run other commands on an unsupported system via a network connection.
• libaaruformat
• C implementation of the Aaru Image Format.
And more!
What's new:
Added
- Aaru Image Format
• DVD CSS related structures.
- AaruRemote
• Use system URI parser to parse AaruRemote endpoints. Allows to set different ports.
- Alcohol 120% disc image
• Support for images created by CDRWin 10 and GameJack.
• Support incorrect implementation of images with track 1 pregap made by UltraISO.
- Apple DOS interleaved disk images
• Support for 13-sector Apple DOS images.
- Apple Universal Disk Image Format
• Detect LZMA chunks.
- BlindWrite 4 disc image
• Consider there is subchannel if we have a subchannel file, ignoring header.
• Reverse engineer unknown field that adjusts the file offset per track.
- BlindWrite 5/6 disc image
• Return empty data where only some tracks has subchannel.
• Support split images.
- CDRWin cuesheet disc image
• Check if media is a CD when generating track list.
• Detect corrupt DVD images created by PowerISO and stop processing.
• Detect incorrect images created by MagicISO.
• Do not reconstruct long sectors when media is not a CD.
• Set application to MagicISO when appropriate.
• Show a message that DVD images created with MagicISO are most probably unrecoverable garbage.
• Show error message when trying to convert multi-session Redump dumps.
• Support Redump GD-ROM dumps.
• Support writing with hidden tracks (NOT CD-i Ready).
• Try to detect, and workaround, disc images that lack the first track data when there's a hidden track, as such created
by PowerISO.
- CloneCD disc image
• More possible values for track mode and index handling.
• Process track entries.
- Device information
• Check Extended CSD is empty on device info.
- Device report
• Check support for SCSI READ LONG(16) in device report.
• Try other ways of getting the SCSI MODE SENSE values that are more effective with certain devices.
• Workaround firmware bug in Lite-On iHOS104.
- Devices
• Better decoding of SecureDigital Card Register.
• More fields to MultiMediaCard's Extended CSD.
• Enlarge sense buffer to 64 bytes.
- Dumping
• Do not cross into each session's first track pregap as this makes some drives fail.
• Dumping of CSS disc key and title keys.
• Enable storing decrypted CSS sectors.
Show last 291 lines
	• Enable to continue dumping non-removable drives if serial number is different using the force option.
• Implement reading SD/MMC using buffered OS calls.
• Workaround some firmware bug in some audio CDs with hidden audio.
• Write media tags to image even when aborted.
• Write MMC/SD card registers to image before closing it.
- FAT filesystem
• Check entire FAT validity to fix identifying between FAT12 and FAT16.
• Check which FAT is valid (first or second) and use it for FAT12 and FAT16.
• Do not return invalid argument when reading a 0-byte sized file.
• Handle directory entries that contain a forward slash in the filename.
• Handle empty directory entries.
• Handle unallocated, but reserved, directories.
• Set encoding before interpreting the BPB.
• Support for FAT32 volumes that uses sectors field in BPB.
- HD-Copy disk image
• Support for different or newer format.
- Image information
• Show Pre-Recorded Information (PRI).
- ISO9660 filesystem
• Do not stop processing a directory when there is 1 or more sectors of data left to process.
• Mounting volumes with an invalid path table.
- Media detection
• Detect ISO 15041 magneto-opticals
• Detect SyJet disks using number of sectors.
• Detect when DVD book type is different from drive's firmware profile.
• PlayStation 5 Ultra HD Blu-ray game discs.
• Ultra HD Blu-ray.
• Xbox Game Disc 4 (Xbox One).
- Media images
• DiskDupe (DDI) image format.
- Media information
• Decode Pre-Recorded Information.
• Decode smaller disc information from older DVD drives.
• More media manufacturers.
• Print Disc Key and Sector CMI information.
• Print recordable Physical Format Information (PFI).
• Show hidden track.
- Media scan
• Allow scanning Audio CD on drives that don't allow READ(12) on them.
- Nero Burning ROM disc image
• Detect incorrect images where the track mode does not match with the track sector size and try to workaround it.
• Implement support for Nero Burning ROM 4 disc images.
• Support alternate audio track mode number in disc images.
• Support reading sector tags in MODE2 disc images.
• Workaround from invalid images created by MagicISO with invalid session descriptors.
• Workaround images created by MagicISO from DVD discs that contain a completely invalid description and a single track.
• Workaround MagicISO bug in images with more than 15 tracks.
- RAW (sector by sector) disk image
• Support setting sector size in raw image when the extension describes it.
• Recognize Toast disc images by extension.
- SCSI response decoders
• Decode fixed or descriptor SCSI sense in a single pass, use whichever was returned by drive.
• Do not skip pages when decoding a page longer than the MODE SENSE buffer.
- Universal Disk Format filesystem
• Recognize volumes that expected a 2048 bytes per sector device but are in a 512 bytes per sector image.
• Set volume serial as volume set identifier.
- VirtualBox disk image
• Support for version 1.1+ geometry.
Fixed
- Aaru Image Format
• Images that got a wrong track end beyond a leadout on dumping.
• Workaround for corrupt multisession AaruFormat images.
- AaruRemote
• Ensure remotes pointing to a UNIX device node have the proper absolute path slash.
• Prevent writing non-long sectors.
• Reading images with a hidden track.
• Reading images with pregaps.
• Setting session.
• Taking account of session start pregaps when writing Alcohol 120% images.
- AmigaDOS filesystem
• Guard identification against too small partitions.
- Apple New Disk Image Format
• Prevent identifying obsolete UDIF images.
• Data offset.
• Reading obsolete RO images, these require resource fork.
• Sectors in obsolete RO images.
• Track flags.
- cdrdao disc image
• Track properties.
• Return session.
• Calculation of sizes when it has CDG tracks.
• Completely wrong handling of PREGAP value.
• Do not allow CD-only tags on non-CD media.
• Reading track flag when track 1 has a pregap bigger than 150 sectors.
• Sectors calculations.
• Setting index sectors on multi-file images.
• Skipping non-present pregap images when there is more than one.
• Detection of track mode.
• File offsets when reading multisession images.
• Image size calculation.
• Invert condition when retrieving flags.
• Partitions on multi-session images.
• Sessions.
• Track 1 pregap.
- Commands
• Do not crash without configuration when no argument is used.
• Do not try to read arguments when there are none.
- CPCEMU Disk-File and Extended CPC Disk-File disk image
• Interleaved sectors numbers.
• Reading of images where the headers have different case.
- CP/M File System
• Handling filenames that contain a forward slash.
- Devices
• 48-bit ATA commands.
• Block size for SD cards, that must always be read using 512b blocks even if their CSD says otherwise.
• Block size from READ(16).
• Correct transfer length type for MMC/SD cards.
• Decoding MultiMediaCard Extended CSD.
• Decoding of USB or FireWire serial numbers with control characters.
• Decoding SecureDigital CID.
• Detect SD/MMC READ_MULTIPLE_BLOCK in Windows.
• Marshalling MultiMediaCard serial number from CID registers.
• Overflow calculations of blocks when device has more than 0x7FFFFFFF blocks.
• READ CAPACITY(16) block size calculation.
• Stack corruption when sending multiple MMC/SD commands in Linux.
- DiscJuggler disc image
• Be more lenient with unknown data images.
• Correct image size.
• Do not generate long sectors on non-CD media.
• Offset problem preventing proper read of most images.
• Processing images with MODE 2 tracks.
• Subchannel types being set incorrectly.
• Track flags not readable.
- Dumping
• Creating sidecar from MMC trying to hash non-existing SD registers.
• Non-CD optical media when drive does not return track list.
• Pregap calculation on first tracks of each session when dumping CDs.
• Re-setting track end when correctly reading a new subchannel that changes the next track start.
• Speed calculations for very fast devices.
• Stop processing sidecar when aborted.
• Use a bigger buffer for READ TOC command that was preventing dumping > 90 track discs.
- FAT filesystem
• Add a guard for FAT12 and FAT16 to prevent an exception on invalid FAT chains.
• Clusters calculation in FAT12 and FAT16.
• Fix reserved FAT entries.
• Force identification of hard disk volumes made by Atari ST with FAT16 filesystems when they're not bootable.
• In FAT filesystem, 0 means no time stored.
• Interpretation of BPB value used by Atari ST in FAT16 partitions of type BIG GEMDOS.
• Mounting a FAT filesystem that does not contain a valid FS_TYPE field and have invalid clusters.
• Null reference exception in FAT filesystem when entry points to a cluster beyond volume.
• Reading FAT when it has an odd number of clusters.
• Regression in setting timestamps from FAT filesystems.
- Filesystems
• Creation of destination folders when extracting files.
• Extracting extended attributes
- Flash-Friendly File System (F2FS)
• Guard against reading beyond partition end when identifying.
- Image conversion
• Converting tape images using command line.
- Image verification
• Off by one error when verifying disc images with tracks.
• Extents not being created for 0 byte files in High Sierra, ISO9660 and CD-i volumes.
• ISO9660, High Sierra and CD-i volumes where the directories span multiple sectors.
- Kreon firmware (XGD dumping and information)
• Correct calculations on dumping and media information.
• Ensure Kreon commands return proper error status.
- Media detection
• Detecting CD-R and CD-RW when dumping if drive reports as CD-ROM.
• DVD discs being detected always as -ROM when the drive returned this profile on dump.
• Misdetecting optical discs as flash drives.
• Number of blocks for 70Gb iomega REV.
• XGD.
- Media images
• Fix full TOC generation.
- Media scan
• Calculating blocks to read when dumping or scanning MMC/SD.
• Seeking test in SD/MMC media scan.
• Incorrect size in multisession media.
• Invalid pregaps detected.
• Long sectors returning subchannel.
• Reading MODE 1 sectors from track marked as MODE 2.
• Returning long sectors in non-CD media.
• Track starts and ends made no sense.
• Unreadable track flags.
• Wrong raw bytes per sector.
• Wrong sessions in some media.
- Parallels disk image
• Images bigger than 4GiB.
- QEMU Copy-On-Write disk image
• Align structures when writing.
- QEMU Copy-On-Write v2 disk image
• Tables calculations that crashed and made unreadable images.
• Getting tracks when writing raw image.
• Returned track properties in raw ISO images.
- Reiser 3 filesystem
• Volume label decoding.
• Descriptor sense decoding.
• Skip invalid EVPD page 80h if it contains non-ASCII characters.
- UNICOS filesystem
• Regression in volume identification.
• Working with disk images bigger than 4GiB.
- VirtualPC disk image
• Reading disk images bigger than 4GiB.
• Reading dynamic images.
- Xbox FAT filesystem
• Exchange access and creation timestamps.
Changes
• Add command line to pause before exiting.
• Clarify anonymouslity of stats sharing.
• Consider 0 to be "current default timeout", otherwise some device commands / operating system combinations fail.
• Create .xattrs folder only in root path of extracted volume.
• Detect all unknown non-removable media as hard disk drives.
• Detect USB flash drives that identify themselves as CD readers but are in reality just block devices.
• Disable calculation of disc entropy on multisession discs.
• Disable dumping with multisession except in AaruFormat and CDRWin formats until 6.0.
• Disable force unit access in SCSI devices during media detection.
• Do not allow converting multisession images to formats that don't support multisession.
• Do not pre-calculate pregaps when dumping on a Plextor as some older models contains firmware bugs that crash the bus.
• Do not write to subchannel log when there's none.
• Ensure first-time setup is invoked even when another command is requested.
• Fix calculating track entropy.
• Fix extents creation from a list of extents to prevent overlapping extents to be added.
• Guard several filesystems against crashes when identifying on a data buffer smaller than needed.
• In image information, only show indexes if there's any index to show.
• Move IRC to Libera.
• Reduce seek times to 100 when scanning MMC/SD cards.
• Rename image analyze command to filesystem info.
• Use ATA Pass Through Direct API in Windows.
• Use same codepath for calculating optical media tag sidecar fields dumping or from image.
• Use SCSI reader detection of maximum supporter blocks to read at once when scanning non-CD media.
do the Fandango!" - Queen
Stiletto
