First post, by akula65
- Oldbie
Source: https://discourse.libsdl.org/t/sdl-2-0-20-released/34407
SDL 2.0.20 released! slouken […]
sloukenThanks to all the people who contributed code and feedback, SDL 2.0.20 is now available!
https://www.libsdl.org/download-2.0.php
This is largely a bugfix release, with the following changes:
General:
SDL_RenderGeometryRaw() takes a pointer to SDL_Color, not int. You can cast color data in SDL_PIXELFORMAT_RGBA32 format (SDL_PIXELFORMAT_ABGR8888 on little endian systems) for this parameter.
Improved accuracy of horizontal and vertical line drawing when using OpenGL or OpenGLES
Added the hint SDL_HINT_RENDER_LINE_METHOD to control the method of line drawing used, to select speed, correctness, and compatibility.Windows:
Fixed size of custom cursors
Linux:
Fixed hotplug controller detection, broken in 2.0.18
