Planet X3 Open Source Edition
First post, by Benedikt
Hi there!
In short: The refactored and expanded source code of Planet X3 is now available under GPL!
See https://github.com/planet-x3/px3_ose
Changelog since the last update release:
Changes under the hood
  • Port of the entire code base from A86 to YASM syntax
  • New build system mostly based on GNU tools
  • Introduction of a "logical screen coordinate" concept and conversion functions
  • Replacement of all hard-coded on-screen addresses with either logical coordinates or variables for pre-converted coordinates
  • Introduction of mode-specific function pointer and data variable blocks
  • Reintegration of the various engine forks, resulting in only one engine: px3_ose.com
  • Full rewrite of most text plotting routines and addition of new ones (lower overhead: string-based rather than character-based)
  • Full rewrite of most low-level tile plotting routines and addition of new ones
  • Full rewrite of rectangle clearing and scrolling routines as somewhat generic functions
  • Partial rewrite of most cursor plotting routines, addition of new ones
  • Partial rewrite of the radar code: Single LUT-based radar screen function, routines that plot horizontal groups of pixels
  • Partial rewrite of the menu code: Now based on data structures for menus and menu entries
  • Refactoring of the AI dispatcher: Now based on jump tables
  • Refactoring of the screen redraw routine and addition of a "lazy update" mechanism
  • More graceful handling of missing files: First search elsewhere, then ask for disk
  • Re-formatting of the entire code base
  • Additional documentation for certain parts of the code base (calling conventions etc.)
New features & Bugfixes
  • Various new video modes
  • Hardware sanity checks that usually catch incompatible video mode choices
  • New audio device: MPU-401 (two modes: MT-32 and General MIDI)
  • New audio device: CMS/GameBlaster (also CMSLPT)
  • Map flipping and multi-climate maps (via 2nd menu level)
  • Enhanced jukebox: Additional tracks for MT-32 (via shift key), in-game tracks keep playing when a game is started
  • Command line options (documented in new "Engine Manual")
  • Map lists stored in a user-editable maplist.bin rather than the engine itself
  • Transparent and/or smooth multi-disk support
  • Masking of transparent areas in modes without transparency support
  • Scout cars (included as useless preview because the artwork is there)
  • Check the actual `+`-key and not just `=` (Software assuming an American kezboard lazout is annozing!)
  • Better bridge construction
  • Further minor improvements and fixes
Reply 1 of 34, by darry
Benedikt wrote on 2023-01-31, 19:17:
Hi there! […]
Hi there!
Nice!
Is there a bit of a back story that you could share as to why this has happened now and not earlier or later (or never) ?
Reply 2 of 34, by Benedikt
The back story is that all previous releases relied on a fork of the engine for every video memory model.
Within every single one of them, all positions on screen were hard-coded as magic numbers.
With the growing number of engine forks this created an absolute maintenance hell and the archaic assembler (A86) did not help, either.
The YASM port that eventually combined everything in one binary then had to become reasonably stable again and the code base had to be tidied up a bit.
Reply 3 of 34, by Benedikt
Addendum:
This is a minimal update package containing just the engine binary, engine manual and a few support files: http://usermo.de/files/planet_x3/updates/PX3JAN23.ZIP.
Copy the content to an older Planet X3 disk and you get most new features, but no MIDI, no modified text mode and no "six islands" map.
Reply 5 of 34, by Benedikt
The original tracks (for MT-32 and SC-55) have always been available as part of the commercial digital download package, namely as ordinary MIDI files as well as MP3s.
The build system of the Planet X3 Open Source Edition, which obviously comes without artwork, pulls everything from the folder of such a download package and converts the MIDI files to a more compact format suitable for the game engine.
Both, the MPU-401 code in the engine and the converter are contributions by Michal Procházka.
Reply 6 of 34, by vetz
Benedikt wrote on 2023-02-04, 10:56:
Thanks, that is great information!
Reply 7 of 34, by Benedikt
As of yesterday, you can download and build version 1.1.0, which incorporates the following changes:
  • Implementation of the two previously reserved EGA modes (i.e. 640x350 3-color and 320x200 16-color)
  • Fix bug in LUT patching for tile set overrides
  • Fix bug in radar LUT (existed since PX3 OSE 1.0.0)
  • Let the (improved) MIDI converter translate missing General MIDI tracks from MT-32 during the artwork import step
Tagged source release: https://github.com/planet-x3/px3_ose/releases/tag/1.1.0
Build instructions: https://github.com/planet-x3/px3_ose/wiki/Build-process
Reply 8 of 34, by analog_programmer
Any clue why I always get this error, while "maplist.bin" (prebuild OSE release 1.0.0 version) is there?
The attachment maplist_error.jpg is no longer available
And after choosing "abort" (no way to proceed with "retry") I always get only "river divide" map with no option to select another map.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 9 of 34, by analog_programmer
I managed to build PX3-OSE executable version 1.1.0 from the source. Unfortunately the "missing" maplist.bin error remains 🙁
EDIT: Removed attached executable ver. 1.1.0 due to mentioned serious bug.
Reply 10 of 34, by M-HT
The error with maplist.bin is a bug in the source code. The fix is described here.
Reply 11 of 34, by analog_programmer
M-HT wrote on 2025-08-24, 08:38:
Thank you!
Seems like the project is abandoned from the last year as this problem is still not fixed in the last official source code version 1.1.0. I've just used your fix in "diskio.s" (I'm not into assembly) and finally the freshly build executable (ver. 1.1.1) works fine 😀 I'm attaching it here, since there's no prebuild working executable version for PX3-OSE available for download (UPX-packed XT compatible com-file):
The attachment px3_ose_111_xt.zip is no longer available
The last things that still concern me are these compiler warning messages
src/maingame/globals.s:90: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:94: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:95: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:96: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:97: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:98: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:101: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:103: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:109: warning: uninitialized space declared in code/data section: zeroing
src/maingame/globals.s:110: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:27: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:28: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:29: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:30: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:31: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:32: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:33: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:34: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:35: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:36: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:37: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:38: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:39: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:40: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:41: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:42: warning: uninitialized space declared in code/data section: zeroing
src/maingame/savegame.s:49: warning: uninitialized space declared in code/data section: zeroing
src/maingame/choice.s:74: warning: value does not fit in signed 16 bit field
src/maingame/cmdline.s:356: warning: value does not fit in signed 16 bit field
src/maingame/main.s:92: warning: value does not fit in signed 16 bit field
src/maingame/main.s:123: warning: value does not fit in signed 16 bit field
src/maingame/main.s:163: warning: value does not fit in signed 16 bit field
src/maingame/main.s:172: warning: value does not fit in signed 16 bit field
src/maingame/main.s:178: warning: value does not fit in signed 16 bit field
src/video/setmode.s:315: warning: value does not fit in signed 16 bit field
src/video/setmode.s:325: warning: value does not fit in signed 16 bit field
src/video/setmode.s:392: warning: value does not fit in signed 16 bit field
src/video/setmode.s:586: warning: value does not fit in signed 16 bit field
src/video/convert.s:543: warning: value does not fit in 8 bit field
src/video/convert.s:544: warning: value does not fit in 8 bit field
src/video/convert.s:545: warning: value does not fit in 8 bit field
src/video/convert.s:546: warning: value does not fit in 8 bit field
src/video/convert.s:547: warning: value does not fit in 8 bit field
src/video/convert.s:548: warning: value does not fit in 8 bit field
src/maingame/backgrnd.s:63: warning: value does not fit in signed 16 bit field
src/maingame/backgrnd.s:415: warning: value does not fit in signed 16 bit field
src/video/scrdraw.s:151: warning: uninitialized space declared in code/data section: zeroing
src/video/scrdraw.s:712: warning: value does not fit in 16 bit field
src/video/scrdraw.s:772: warning: value does not fit in 16 bit field
src/maingame/game.s:811: warning: value does not fit in signed 16 bit field
src/maingame/game.s:854: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1013: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1033: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1199: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1226: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1243: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1261: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1279: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1414: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1441: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1452: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1523: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1537: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1594: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1635: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1675: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1698: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1723: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1748: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1773: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1798: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1824: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1937: warning: value does not fit in signed 16 bit field
src/maingame/game.s:1977: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2012: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2045: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2067: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2126: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2183: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2213: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2243: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2274: warning: value does not fit in signed 16 bit field
src/maingame/game.s:2429: warning: value does not fit in signed 16 bit field
I wish there were implemented mouse support in PX3-OSE and freeware map editor...
UPDATE: I totally forgot about UPX's "--8086" XT compatibility switch. Sorry, there's a new attachment with updated UPX-packed executable, which is also compatible with 8088/86 CPUs.
Reply 12 of 34, by Benedikt
Aside from the observation that David Murray appears to have moved on from Planet X3, it is not abandoned, because I - some rando from a different continent - am still the “active” maintainer.
However, most notable development work has been happening on the obscure-hw branch for quite a while, namely to support... obscure hardware.
The bug you mentioned is now fixed.
On this occasion, I have also published a few other improvements that have been rotting away on my hard disk.
Fresh from the git log, the newly published changes are:
  • fix bug in processing of /r argument
  • add /t argument to disable transparency
  • also use lazy tile updating with transparency=on
  • make scouts useful and add soldiers
  • add missing terminating 0 to MAPLIST.BIN file name
For the soldiers, a unit that comes from your headquarters rather than a factory, I came up with a slightly different concept to make sure that they are not entirely useless:
They are the only units that are permanently in a “fire at will“ mode while you can still move them around.
In exchange, you cannot actually manually aim at anything, but you would not be able to do that, anyway, because they are only strong as a group.
Reply 13 of 34, by analog_programmer
Benedikt wrote on 2025-09-03, 19:16:
Aside from the observation that David Murray appears to have moved on from Planet X3, it is not abandoned, because I - some rand […]
Hi,
Nice to see, that you're still maintaining the project.
Do you have any clue why YASM compiler gives me these warnings?
The produced .com executable seems to work fine.
Reply 14 of 34, by Benedikt
You can completely ignore those YASM warnings.
The uninitialized variables are explicitly uninitialized, i.e. semantically hold no sensible value, but because they can only be genuinely uninitialized at the very end of the program where YASM can trim the COM file, they end up being implicitly initialized with zero, instead.
The warning “value does not fit in signed 16 bit field” is also easy to explain:
Imagine you want to advance a 16 bit pointer by 32 KiB.
The most intuitive way to do so is to add 32768, but that number falls outside the -32768 to 32767 range of signed 16 bit integers, i.e. it wraps around and you actually end up adding -32768.
This, however, makes no difference, because the 16 bit result will wrap around, one again.
Most programmers prefer the intuitive spelling in such cases.
Reply 15 of 34, by analog_programmer
Benedikt wrote on 2025-09-04, 14:24:
It seems like YASM compiler is doing a good job here 😀
The warning “value does not fit in signed 16 bit field” is also easy to explain: Imagine you want to advance a 16 bit pointer by […]
I thought, that probably this is something like trying to set "long" value to "int" variable, but I don't know what's the situation in assembly. Thanks for the explanation!
Reply 16 of 34, by Benedikt
analog_programmer wrote on 2025-08-24, 10:32:
You sent a few gears in my head spinning and I eventually remembered where I had seen something along those lines before:
This Facebook post introduced an independently developed map editor for Windows as early as 2018.
It only handles uncompressed maps, but the compression is just off-the-shelf ZX7.
For your convenience, this is the direct link to the google drive folder.
Note that I have never tried that program.
Reply 17 of 34, by analog_programmer
Benedikt wrote on 2025-09-17, 11:12:
You sent a few gears in my head spinning and I eventually remembered where I had seen something along those lines before: This F […]
Thanks for the links! I'm not a(n) (anti)social networks user, so freakb00k shows me almost nothing from the related posts, but it's enough. From the pictures it looks good. Sadly it's abandoned in early developing stage. I may try it in Wine, 'cause Wine is my winbooze.
Reply 18 of 34, by Kekkula
I cannot get this working.
i've copied assetconv to px3_ose directory but it still gives error when running get_assets
./get_assets.sh: line 127: ../assetconv/tdy2cgt_screen: No such file or directory
./get_assets.sh: line 128: ../assetconv/tdy2cgt_screen: No such file or directory
./get_assets.sh: line 129: ../assetconv/tdy2cgt_tileset: No such file or directory
./get_assets.sh: line 130: ../assetconv/tdy2cgt_tileset: No such file or directory
./get_assets.sh: line 131: ../assetconv/tdy2cgt_tileset: No such file or directory
Running make only makes px3_ose.com to build directory, copying that to original distro.720 directory and running the game from dosbox gives maplist.bin error.
Also trying to make px3_full will error out with.
make: *** No rule to make target 'build/assets/tile1.cgt', needed by 'graphics_160x200_cgt'. Stop.
Reply 19 of 34, by Benedikt
Ah, I see.
Those are the compiled binaries of the converter programs that generate the tile set and screen files for the tweaked text mode.
You either need to compile them – they are in the assetconv repo – or remove all references to them.
Failing that, you can copy maplist.bin to distro.720, too, alongside px3_ose.com. The commercial release came with the map names and types hard-coded.
P.S.: Make sure that you are using the obscure-hw branch, because I presume that that is what you are after.
P.P.S: For the experimental Olivetti M24 GO329 code path, specifically, appropriate video BIOS extensions need to be available. I am not sure whether they were provided as option ROM or via TSR, but you will surely have means to find out.
