My Very Long Bus Adventure.
Reply 40 of 266, by Chadti99
Removing the 5-6 jumper from jp18 allows me to boot with the TurboChip but CHKCPU reports L1 is in WT mode. And L2 isn’t detected, dang it.
Reply 41 of 266, by PC-Engineer
  • Make sure, that JP5 and JP6 are set to 1-2
  • JP11: 2-3
  • JP16: 1-2 & 4-5
  • JP17: 1-2 & 5-6
  • JP18: 1-2
  • JP19: 1-2 & 3-4 & 5-6
  • JP20: 1-2
  • JP21: 3-4 (L1WB) or 2-3 (L1WT)
  • JP22: 1-2 & 4-5
  • check correct setting in BIOS feature setup
995.78 KiB
930.71 KiB
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 42 of 266, by Chadti99
Got it! For some reason I had jp5 and jp6 set incorrectly, that and changing both L1 and L2 back to WB in the bios. thank you!
Seeing some better numbers now for L1 cache, slightly slower in L2 and main memory speeds.
Reply 44 of 266, by Chadti99
Dropped an S3 Trio32 in, upgraded to 2MB after photo, and now hitting 17.1 in Quake!
Reply 45 of 266, by pshipkov
17fps - getting warmer.
On this board and chipset L2 cache in WT mode is better.
Actually only very few socket3 motherboards produce better performance with WB mode, but when it works is great.
retro bits and bytes
Reply 46 of 266, by Chadti99
Load up SDD and it squeezes a bit more out of the Trio32, 17.6 up from 17.1.
I know it’s kind of cheating but love to see VESA modes produce results!
Reply 47 of 266, by Chadti99
pshipkov wrote on 2021-10-11, 21:17:
Good to know! How far am I off the mark currently? Do these numbers line up with the 256k cache I have installed?
Reply 49 of 266, by pshipkov
I think the highest Quake 1 result with 486 CPU running at 160MHz is 18.8 fps, with Ark1000VL (default Phil's benchmark C).
After the 17'ies it get exponentially steeper.
You will most likely need 1024Kb L2 cache running at tightest BIOS timings for that.
Interesting DN3D result. Didn't expect such a difference.
Reply 50 of 266, by Chadti99
pshipkov wrote on 2021-10-11, 21:47:
I think the highest Quake 1 result with 486 CPU running at 160MHz is 18.8 fps, with Ark1000VL (default Phil's benchmark C). Afte […]
Got it, I’ve got cache and an ARK on the way, I hope, 🤣. Really tempted to pull cache out of another build, must resist…..
Yah def interesting results with Duke3D but to be fair to the CL5429 the scores are within 1fps for both cards at 320x200, so if you just want to play Duke as fast as possible on this board, the CL is fine.
Happy to report the image quality in Windows 98 is also quite good compared to the CL. Unfortunately I’m still stuck in interlaced modes at 1024x768x15bpp. Don’t plan to spend a lot of time in Windows on this setup though.
Reply 51 of 266, by Chadti99
Alright couldn’t resist, made a compromise and only needed to pull half the sram out of another build, the easy half to access. Now I’m running 1024k cache on the GX4 and pulling 17.9fps in Quake on the Trio32. So close to 18. Although using a VESA mode pushes it over, but we’ll leave it out for now.
Reply 52 of 266, by Chadti99
Has anyone experimented with the mclk dos tool to try and squeeze an extra frame or two?
For whatever reason it doesn’t recognize my Trio. I’ve tried a couple of times to force a manual config but this ends with a freeze or corrupted screen.
Reply 53 of 266, by Chadti99
Okay, so I was using the wrong syntax for the parameters. Clocked it up as high as I dared but only saw 0.1 fps difference in the 640x480 modes of Chris’s and PC Player’s benchmarks. Obviously within the range of error but it was consistent. No gain in Quake or Duke in the lower resolutions that I tried.
The pic shows 59MHz but I took it up to ~85Mhz, assuming it was even working.
Reply 54 of 266, by pshipkov
for vga resolutions perf is cpu bound, so overclocking the video adapter wont make a big diff.
17.9 is a good number. you are above most mobos already, but with this setup you should be in the 18s.
so, what else is not on max ?
Reply 55 of 266, by Chadti99
pshipkov wrote on 2021-10-12, 14:27:
Are you sure? According to your graph, I think it’s yours, I’m right on the mark at 17.9 with this combo of hardware, specifically the Trio32.
Reply 57 of 266, by Chadti99
pshipkov wrote on 2021-10-12, 16:19:
I should check my own graph before speaking, so i stand corrected.
Somehow in my head S3 Trio VLB was in the 18s. 😀
Haha, yah pretty crazy the ARK is basically a full frame ahead.
Reply 58 of 266, by matze79
No Wonder GD542x is suffering from 16bit Bus Connection, or multiplexed 32bit Bus resulting in Maximum Bus Speed of ~16Mb/s
A Fair Comparision would GD543x.
Reply 59 of 266, by Chadti99
matze79 wrote on 2021-10-12, 18:55:
If I can get my hands on a VLB based GD543X I’ll give it a go!
