![DSC-1156.jpg](https://i.postimg.cc/YvxF2SfW/DSC-1156.jpg)
After many hours of gradual refinements, I've completed a TinyLlama 2 (with wavetable selector) embedded version of a 3d printed mini IBM PS/2 25 that I had designed last year. Here are the STL files and list of materials - Printables - and here are some more detailed build instructions - Instructables. It's got built in power supply, LCD monitor, audio amplifier and speakers, case fan, front panel SD card access, back panel with the a TinyLlama control board, and a big red switch to turn it all off.
There are several pieces that are different for the TinyLlama - mainly the electronics board for mounting the PCB and holes for the ports.
![DSC-1142.jpg](https://i.postimg.cc/NKW0cqZH/DSC-1142.jpg)
To use the internal power supply it required adding 5V connection to the Llama. This was done by very carefully soldering in some connections at these points:
. Thanks to Aaron707 for working this out. Here's what it looked like on mine:
![DSC-1145.jpg](https://i.postimg.cc/7Jx6W3dt/DSC-1145.jpg)
Here's a photo of all the electronics before they were mounted to test:
![DSC-1149.jpg](https://i.postimg.cc/jCrJfNg7/DSC-1149.jpg)
The PS/2 25 has a disk access light I used the circuit that Eivind had suggested to control this. I connected this to the HDD Clicker from Serdaco to add even more authentic feel for the experience.
Here's a bunch more photos of the internals. It's not easy to get good camera angles in there, but I can try to elaborate if there's any questions.
It's been a very fun project - thank you Eivind for your great designs and help, and thank you Aaron707 for sharing this project and your thoughts!
