Reply 20 of 36, by Jackhead
First Bench Base clock GPU with futuremark 3d 2001 Windows XP 32bit / i7 @ 4,5Ghz:
The attachment IMG_4461.JPG is no longer available
Im not sure because i bench my v5500 under win98se with 3d mark 2000. I think a 5500 max oc get around 3500 on 2001?
Win98SE: Asus XG DLS - 1x P3 Xeon SL4XY 900/100/2- SG Voodoo 5 6000 PCI - 1GB RAM ECC- Diamond Monster Sound MX300 - Roland MPU-401AT (Yucatan FX)
Reply 21 of 36, by Irinikus
Here's the result form my Voodoo5 55oo PCI on my Dual 1GHz PIII system for comparative purposes. (Also slotted into a 66MHz slot, with the machine running XP Professional.)
YouTube
Reply 22 of 36, by Jackhead
I think you can easy get 1000 more points when you switch to a P4 System. 3d mark 2000 dont work on xp ? Cant start it.
But im sure the 6000 will get there over 10k. 2001 is really hard for a voodoo, impressive.
Reply 23 of 36, by Irinikus
I'll give it a go in the dual 2.8GHz Slot 603 XEON, once I have it up and running.
Judging by the result you got, considering the CPU that you're using, I don't expect to see much of an improvement?
EDIT: Sorry, I'll check to see if I have records of the 2001 score I got with my card!
Unfortunately I didn't take a picture of the Voodoo5's result, but here's the Quadro2 pro's result on the same machine: (Bothe the Voodoo5 and the Quadro2 Pro lack the shader hardware to complete all the tests!)
YouTube
Reply 24 of 36, by Jackhead
Voodoo 5500 System - P4 Northwood 3,06GHz - Windows 98SE my 5500 system you can look.
Reply 25 of 36, by Irinikus
Then the CPU definitely makes a difference! 😀
YouTube
Reply 26 of 36, by Jackhead
On base yes for example i got 4800 points 2001 with 990X base clock 3,3Ghz , on 4,5GHz 200 points more.
So yes but a 5500 perform best with a pentium4 (optimal will be a presscott 2,8GHz on 478 agp, if you have pci even higher..).
Reply 27 of 36, by Jackhead
I did some more testings with another Asus Board.
This time was the goal Win98SE. I choose the P5K-WS with one PCI-X Slot.
Installed with custom chipset drivers. I works really good! Win98SE with ICH9 !!
Just the IDE bus has some problems, but windows load basic driver.
Atm i have a small CPU on the board but i will switch to a E5800 soon!
But so far very happy! Did a quick 3d mark without problems.
The attachment IMG_4481.JPG is no longer available
The attachment IMG_4483.JPG is no longer available
Reply 28 of 36, by Jackhead
I add some extra cooling , and some new fans 😀
The attachment IMG_4488.JPG is no longer available
The attachment IMG_4489.JPG is no longer available
Reply 29 of 36, by H3nrik V!
Isn't there decoupling capacitors in the middle under the VSA chips?
Reply 30 of 36, by Hezus
Jackhead wrote on 2023-06-16, 17:37:
That looks absolutely bad ass! I've always liked the noctua colour scheme.
Visit my YT Channel!
Reply 31 of 36, by Jackhead
installed 3x noctua NF-A12x25 FLX to provide good airflow for the Voodoo5 6000. Two on front, one on back. Chipset fan, 2Gb DDR2-1066 with E8600@4,5GHz Win98SE
The attachment IMG_6032[1].JPG is no longer available
The attachment IMG_6031[1].JPG is no longer available
The attachment IMG_6035[1].JPG is no longer available
Reply 32 of 36, by H3nrik V!
Interesting W98 setup you have there. Is it running good with 2GiB of ram with that "Service Pack"?
Reply 33 of 36, by H3nrik V!
Just read up on that unofficial Service Pack. Definitely something I'm gonna play around with on a BX setup with a gig of RAM, playing a little with cacheable range on P2's ..
Reply 34 of 36, by Jackhead
1-2GB runs great with the patch, i also tryed 2x2gb but thats to much 😀 I would go with 2x512MB but ddr2 1GB was cheaper as finding 2x 512Mb 1066..
Reply 35 of 36, by H3nrik V!
Nice, I'm so much gonna play around with that 😁
Reply 36 of 36, by mikepedo
Hi Jackhead! Sorry , I also purchased a Strange God PCI with an ASUS P6T WS PRO motherboard. Could you kindly tell me the settings in the bios to solve the "Out Of Range" problem, and perhaps where to find the WIN98SEOS fix for X58? Thank you!
