First post, by Half-Saint
Hey all,
I am about to retire my super socket 7 build (running DOS and Windows 98SE right now) and am thinking of a replacement.
I have this very nice blue Gigabyte GA-6OXT board with a Tualatin Celeron 1.3 GHz processor and 512MB of RAM. It occured to me that I could build a relatively good blue themed system around this board that would blow that K6-2 out of the water. I don't think I have any blue video or sound cards at the moment. I had a blue Hercules 3D Prophet Geforce 2 GTS 64MB back in the day but this card would probably be a little bit weak. As far as sound cards go, I have an Audigy 2 ZS Gold for example but it's black.
Any ideas for video/sound cards? I'm not looking to build THE best socket 370 system, just a decent one for not too much cash.
As for the case, I'm looking at Fractal Design Focus G in blue and with a window.
1.06 MiB
Reply 1 of 27, by nd22
A geforce 4200 would smoke very game up to 2001 and would be a perfect match for this system together with 98SE. If it is hard to find or expensive a geforce 6600 standard would provide an even bigger performance at a lower cost. I do not know much about sound cards but I think Creative live would be a very good choice for 98SE.
Reply 2 of 27, by tannerstevo
Aopen made blue sound cards. I have one with a yamaha chip. Aopen Cobra.
And I also have a blue FX5900 Witch I think is Gigabyte, but they are both stored away, so I have no pictures.
Edit: the fx5900 is a chaintech.
Reply 3 of 27, by psychofox
Hercules Fortissimo 4 is also blue. But i am not sure how good it is on W98 games.
Edit:
Just remembered, also i have an FX5500 which is quite good for W98 build.
Looks just like this but with blue pcb:
I havent checked the prices lately but they are quite common so probably they dont cost a fortune
Reply 5 of 27, by Bruno128
Only listing what would fit this system:
Blue sound cards:
Sound Vision SV550 (Yamaha)
AOpen cobra aw-850 (CMI8738)
Some audiophile stuff but that’s not exactly for games.
Blue video cards:
Some gigabyte (GA-660) and Abit siluro (GF4MX) models.
Hercules 3D prophet (Kyro)
Blue voodoo2 exists as well (by ProVideo)
Now playing:
The Dig: 1995 VLB 486
Arcanum: 2003 Acrylic build
SBEMU compatibility reports list | Navigation thread
Reply 6 of 27, by Bruno128
Also, “Blue Lightning” is a 386 cpu name so you might be confusing people searching the fora.
Now playing:
Reply 7 of 27, by BitWrangler
IBM already confused ppl, with the 486 DX2 following on from the supercharged 386 SLC3/BL3 ...
file.php?id=158959&mode=view
That's actually running in SL2/BL2 mode 2x multi there.
Reply 8 of 27, by Half-Saint
There, fixed the title 😀
Lodge_ wrote on 2024-03-08, 06:18:
psychofox wrote on 2024-03-08, 05:52:
I have Hercules Muse 5.1 in my W98 build and it works fine, and yes, it's blue.
I actually found a Muse sound card in one of the boxed the other day 😀 Although I might still go with Audigy 2 ZS as I have an X-Fi front panel and always wanted to use it.
Reply 9 of 27, by BitWrangler
Could maybe go for Blue Thunder, which was a "what if we crossed CHiPs and Airwolf" 80s TV show .. https://www.youtube.com/watch?v=8_ZQIf6YB7E
Reply 10 of 27, by InTheStudy
Scratch my scratch that.
Ok, someone less distracted - this would fit that board, right?
126.69 KiB
Because I found a '98 driver that supports the BCM5703 chipset.
Reply 12 of 27, by InTheStudy
Half-Saint wrote on 2024-03-11, 19:37:
It says Apple Computer on the card so I'm guessing that's an Apple card. The slot connector is definitely not for the PC.
It's standard PCI-X, nothing proprietary. A perfectly normal connector for PC's of the era, not just Macs. And yes, it's an Apple card - but if you're not needing it at boot time, that shouldn't matter.
In the interests of time, here's a HP PCI-X card using the same chip. Sadly however, only Apple made it in blue.
54.94 KiB
Reply 13 of 27, by chinny22
Funny enough I have an Albatron blue GF4 Ti 4600 that spoils my green themed P3.
Would be perfect for your build not exactly cheap though.
I really like this idea though!
Reply 14 of 27, by H3nrik V!
Will that pcix card even work in a normal pci slot? Is it in any way backwards compatible?
Reply 15 of 27, by InTheStudy
H3nrik V! wrote on 2024-03-12, 05:08:
It *should* be. Most PCI-X cards are compatible with standard 32bit. The BCM5703 chipset is also listed as natively supporting PCI32 in addition to 64 bit PCI-X. That said, there's always a chance that something will not work, this is 20 year old vintage hardware from the days where two brands of PC would barely co-exist, let alone two competing platforms.
Reply 16 of 27, by H3nrik V!
InTheStudy wrote on 2024-03-12, 09:31:
So really, there just needs to be room for the rest of the edge connector to not hit anything on the mainboard? Cool!
Reply 18 of 27, by InTheStudy
H3nrik V! wrote on 2024-03-12, 13:54:
I'm about 80% confident. Which is pretty low to be fair, but they're like €20 on eBay right now so at least it's not silly money if it doesn't work out. And if it doesn't work out, it's the specific card and motherboard - not a general PCI-X/PCI compatibility issue!
And it's the only blue PCI gigabit nic I found. 😁
Reply 19 of 27, by chinny22
This project is different enough to really catch my interest.
Seems like Albatron made a number of blue graphic cards so may be able to get something more within your price range.
BitWrangler wrote on 2024-03-11, 15:25:
Show about flying police motorbikes!? 80's me would have loved that! hell, I'm now in my 40's and probably still watch it 😉
