My DOS/Windows 98SE PC
First post, by manic232
Thought I'd share my retro PC with pics and thoughts with you.
Intel 440BX Motherboard
Pentium 3 600Mhz CPU
256mb PC100 SDRam
3dfx Voodoo 5 5500 GPU
Creative SB AWE64 Gold Sound Card
17” iiyama CRT Monitor
Cambridge Soundworks SBS52 Speakers
Front loading HD bay (to easily change hard drives DOS/Win98)
And the best bit last, a real Roland MT-32 😀
I have been using DOSBox for some time, but really wanted to get my hands dirty with DOS and Windows 98 SE, so set about building the above PC. My main goal was to try and get DOS 6.22 up and running to play 90's point and click adventure games like the Lucas Arts gems, Maniac Mansion, Day of the Tentacle etc. I also wanted to use a real MT-32 if possible.
I know that the PC is well over specced for just pure DOS, but I also wanted to use Windows 98 for Glide games, I figured it may be easier to slow down DOS with MoSlo that to try to speed it up.
The build went fine, no real problems at all, powered on first time and I was very happy. The real problems came when I started playing games! Some games work fine, most of the Lucas Arts games install and run without issues, but one problem persisted, getting the MT-32 running. I had never used one back in the day as they were very expensive back in the days of yore, so i was a little green under the gills with regard to knowing how to get it working. I thought you just plugged it into your sound card and that was it. After doing some research on this and other web sites i realised that you need an MPU MIDI interface card, great i thought no problem, i'll just to on eBay and pick on up…. yes I know the knowledgeable among you are laughing at me now! The prices for these cards on eBay are quite silly, frankly the eBay listings belong in an episode of Ripley's Believe it or Not! Then there is the problem with the Rev 0 MT-32 (which I have) some games cause the unit to display a buffer overflow error when using the MT-32 the sounds are all messed up or won't play at all. To cut a long story short, i have given up the idea of trying to get the MT-32 working on this rig, this leads me to my next point…
… I have come to learn that DOS gaming is a pain in the butt!! there i said it, i don't care who knows 🤣. Like i said most games run OK (apart from MT-32) but there are some that just point blank will not work at all, The Humans for example keeps coming up with low memory errors, Lemmings 2 sometimes works but again sometimes randomly comes up with error message about upper memory or lower memory, can't remember now and I was having issues with CD Rom and Mouse drivers not working, I managed to edit my autoexec.bat and config.sys files to load mouse and CD drivers, but sometimes without warning and totally at random DOS rather rudely deletes the lines from the autoexec.bat and config.sys, why this happened is totally beyond me. Then there is the most important factor, how the games look and run. the games that did work, worked well, but looked rather pixelated to me, frankly to me games look better with DOSBox and a filter like SxSAI or similar.
So to bring this to a conclusion, I have now decided to use a cheep (ish) Dell desktop to run DosBOX and a few other emulators (I call it my Emulation Station 😀), i still use the 17” iiyama CRT Monitor and speakers etc, but I get trouble free gaming with this PC, games run great, look better and the MT-32 works just fine without me having to re mortgage my house for a MIDI controller card and if using an SVN build of DOSBox you can even eliminate the buffer overflow error by making a change in the .conf file... superb!
The specs of the Dell are:
Core DUO 2.13Mhz
4GB Ram
80GB Hard Drive
AMD 4000 Series GPU
I sprayed the 2 sides of the Dell white to (kind of) match the rest of the components (my OCD would not allow a PC that does not match the monitor, speakers etc 😀)
This whole SAGA has made me realise how lucky us retro gaming geeks are having an awesome emulator like DOSBox, the creators of this software are pure legends and deserve a knighthood.
Reply 1 of 31, by Mau1wurf1977
Fantastic story and thank you for sharing! Yes DOS machines are a lot of work and parts can be expensive and finicky. For many of us here it started with the desire to play old games but then we enjoy playing with the old hardware, DOS, Windows and Drivers even more 😀
Emulation is indeed fantastic and if you want to play games I highly recommend it. I also admit that most DOS games I have played, I did so on DOSBox with the comforts of a modern machine.
The retro computers are for tinkering, documenting things, sharing knowledge and all of that.
My YouTube channel
Reply 2 of 31, by F2bnp
That's pretty slick!
Reply 3 of 31, by MaxWar
Nice story 😀 And what is that thing left of the keylock on your P3?
Looks like a stereo PC-speaker :p
Dosbox is awesome but As Mau1wurf1977 said, some of us just love to mess around with old hardware 😀
Just to add one little thing, your MT-32 should have worked with your AWE64, at least for many games. You only really need the very expensive real mpu-401 interfaces for games that require the "intelligent mode" .
You just need to make sure the feature is enabled with your aweutils and you select the proper interface port in the game usually 300-330.
As a side note, i play my games on real retro pcs now but i miss the filtering options of dosbox to smooth out those huge pixel. One solution i like to use is to output the computer on a CRT TV, it does a wonder of smoothing things.
I played a game of the original 16 colors Duke Nukem on a 32" TV the other day, it was fantastic!
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
Reply 4 of 31, by manic232
that is a front loading hard drive bay to easily swap hard drives. That way I can easily switch between DOS and Windows 98 SE, kind of does look like a speaker i agree!
Thanks for the tip about the AWE64 and aweutils, I will certainly investigate further in that regard.
I like the idea of using a CRT TV for gaming, kind of like having a built in 2XSAI filter 🤣
Reply 5 of 31, by Stull
Nice systems. What's that Speeze thing? Is it some kind of sound absorber? Does it actually make a difference?
Reply 6 of 31, by manic232
Thanks Stull, yes it is a sound insulator, it came with the case I got, I didn't fit it myself, to be honest I cant really say it makes any difference at all, I wouldn't have bothered to fit it if it didn't come with the case.
Reply 7 of 31, by RacoonRider
Nice and clean! I love that "devil inside" sticker 😀
And the MT-32... You're lucky 😀 When yesterday my girlfriend asked me what I wanted for my birthday, I said: "Nothing, I really have everything I need", while a large part of me was screaming inside: "MT-32! You want MT-32!" 😁
Reply 8 of 31, by manic232
🤣, was not as expensive as you might think, I got mine for about £100 on eBay, i think they were about £400-£500 when they first came out back in the day
Reply 10 of 31, by chinny22
Nice basic case with no over the top “styling” I like it! Good build too.
Only thing I would change is 512MB RAM (just casue windows likes it) and a Sound Blaster Live or above for EAX (depending on what games you play that is) but really there isn’t much this PC won’t be able to do
I remember when everyone had the HDD caddy’s (accept me) that in its self is retro
Bit late now but you probably could of played the dos games from Win98 (I admit that is cheating a little) but even then dosbox is better than a real PC 9 times out of 10 if your just after gaming. Your “problems” are actually challenges once they are fixed the whole thing gets a little boring
Reply 11 of 31, by manic232
I did consider 512mb of ram, but there is one game I like to play (Actua Golf 2) that will not work with 512, you get a not enough memory error if there is more than 256mb ram installed. I don't know much about EAX, what does it do? Would there be a significant difference for old school games?
My System: SuperMicro P6SBA Motherboard, Win98SE, PIII 600Mhz, 256MB Ram, Voodoo 5 5500, SB AWE 64 Gold Sound Card, Roland LAPC-I
Reply 12 of 31, by chinny22
fair enough then, really Win9x games came out when 128MB was alot, 256 was about the time people were moving over to XP 512 just gives you extra to play with, but your not going to miss it.
EAX gives better sound effects in games like background noise, more defined echo’s in tunnels, stuff like that. Some games you notice it alot like NFS, other games like Diablo2 not so much but still abit. Do a quick search on the internet and you can find a list of what games support it if your playing those games then I’d recommend it Sound Blaster Lives are cheap and plentiful, Audigy’s start to cost a bit more but the Audigy 2 ZS is a very nice card!
Reply 13 of 31, by Mau1wurf1977
vetz wrote:
If you don't care so much about the LCD screen on the MT-32, the MT-100 does the same for a lower price. I got my MT-100 for 25 dollars.
Careful 😀 The MT-100 has the PCB of the revised MT-32. Roland refers to this as MT-32 (new) in their service manuals.
Reply 14 of 31, by vetz
What do you mean? The MT-32 has three revisions to it, the latest added a headphones jack on the backside, which I thought was the same as the MT-100? Some games do only sound 100% correct on the old revisions, and some only on the new revisions, but most ones work no matter what revision.
Reply 15 of 31, by Mau1wurf1977
There are two versions of the MT-32. MT-32 (Old) and MT-32 (New). The other modules are CM series and have their own differences.
Good thing about the MT-32 (New) is that it avoids the buffer overflow issues. But apart from that it's the odd module out as it's not 100% compatible with the original MT-32 and doesn't have the 33 extra sound effects of the CM series either.
My YouTube channel
Reply 16 of 31, by kool kitty89
The later MT-32 also lacks the manual digital volume control which can be used to avoid clipping problems in some games. Albeit, they can still be software configured to address this.
Reply 17 of 31, by Mau1wurf1977
Yup exactly 😀
When the MT-32 (Old) is really busy it doesn't react to you changing the volume wheel.
Wing Commander is an example of the clipping. At the fireworks scene you have to set the volume to ~ 65 on the MT-32 (Old) to not get any clipping. On all other units you are out of luck.
Reply 18 of 31, by manic232
Seems to me if you have an old or new MT-32 your going to hit some kind of problem, i think im glad i got the old one though, as reading this and other posts the old version seems to have less issues and can be resolved easier with DOSBox anyway.
Reply 19 of 31, by CapnCrunch53
What an excellent-looking system; the drives and caddy match the case color just about perfectly! No shame in using Dosbox; it certainly is much more convenient, and lets you emulate some hardware that one otherwise might have to spend a considerable amount on.
PCs, Macs, old and new... too much stuff.
