Artex's Build of the Week: Altered Beast
Reply 20 of 25, by Skyscraper
Darkman wrote:
Just wondering, how does the 1.4Ghz Tualatin compare to an Athlon 1400? obviously its also up to whether a game uses SSE/3DNow, chipset , etc. But given similar components, how would it compare?
Im guessing the Tualatin runs much cooler, thats probably a given.
In games the Athlon (Thunderbird) and P3-S is almost equal clock for clock, when it comes to other stuff they trade blows.
See this review for more information.
http://www.xbitlabs.com/articles/cpu/display/ … l-tualatin.html
Reply 21 of 25, by Darkman
Skyscraper wrote:
In games the Athlon (Thunderbird) and P3-S is almost equal clock for clock, when it comes to other stuff they trade blows. […]
ah I see, they are more or less the same it seems in most ways.
I still find it funny both are beating the Pentium 4 in just about every task minus Quake3.
Reply 22 of 25, by kokornov
Artex wrote:
kokornov wrote:
You can try to use modded BIOS for P3B-F (ver NOA) for correct CPU detection: http://www.rom.by/files/P3BF_Noa.BIN
Do you have a readme or any additional info about this BIOS?
No. Its difference from Asus's 1008 beta 004 is in added microcodes for Tualatin and corrected CPU name display - that's all I know.
To activate microcode update enable "BIOS update" option in CMOS Setup. If you enable it on stock BIOS, the board will show warning during POST.
Reply 23 of 25, by Artex
Gotcha - I grabbed a different BIOS with the microcode update. I'll try this one - thanks!
EDIT: BIOS now shows Tualatin PIII 1.4Ghz. Thanks!!
Reply 24 of 25, by Artex
Small update today.. I forgot about a boxed MSI Ti4600 8X I had tucked away, and this card is stable (and fast) as hell!
And a couple of screenshots showing that "NOA" BIOS that correctly shows the Tualatin processor name..
Reply 25 of 25, by Skyscraper
Nice!
It seems that I need to try more GF4 ti 4x00 cards to see if I also can get a stable Tualatin P3-S 1400 build with a BX motherboard.
At the moment I have a Abit BH6 build with a Tualatin Celeron but Im thinking of switching to the Aopen AX6BC so I can try a P3-S 1400 again.
