Another retro PC - iBM Aptiva
First post, by brad1982_5
Just picked up this fine example that I won on eBay for just under £30 in my local area. I went and collected it just an hour of the auction ending.
It's a IBM Aptiva 486DX2 66 MHz, I don't know if it's Intel or not yet. Showing as 16MB RAM, 540MB Hard drive, Quad speed CD-ROM, Sound Blater 16 VIBRA (I think) with an awesome 14" CRT SVGA monitor and a Model M2 keyboard.
The seller was very helpful in getting this loaded in the car.
It will have a good clean. Here are the pics.
Reply 1 of 39, by Arctic
Really nice!
I like the design on this one 😀
Reply 3 of 39, by brad1982_5
Cheers guys, will post updates during and after cleaning. 😀
Reply 4 of 39, by TELVM
Wow those pics give me a stroke of nostalgia, I had an identical Aptiva 2144 back in '93 or so. 😀
Awesome machine for its day, built solidly and in style. It came with a sort of fast hibernation called Rapid Resume which rocked at the time.
Looks very well preserved.
Let the air flow!
Reply 5 of 39, by oerk
Nice machine! I really like these compact cases.
Probably IBM 🤣
Also, no cache installed?
Reply 6 of 39, by chinny22
You should have some fun with that, look forward to the after pics,
Reply 7 of 39, by brad1982_5
oerk wrote:
Nice machine! I really like these compact cases. […]
Probably IBM 🤣
I think your right, still yet to check though what brand of CPU it is.
Yep I'm afraid no there is no cache memory installed 🙁
Cleaning is nearly finished. Keyboard is taking two days alone during the evenings! Now just letting the keys air dry and finally pop them back in tomorrow and have a finished keyboard!
Reply 8 of 39, by brad1982_5
All cleaned, maybe the odd bit to do but it's much better now.
The base unit was a breeze to clean. Took it to work and used our air compressor to get rid of the loose dust and finished it using cyberclean putty. The monitor was easy too, that just had lose fluff inside so did'nt even take the back cover of that. Just yet again use the air compressor and used a torch to shine light through the vents afterwards and it's spotless.
The keyboard however took alot more work. That was cleaned all manually. (Warning, lots of pictures.)
Reply 9 of 39, by JayCeeBee64
Rank Retired
Retired
Great cleanup job! Did you take care of the PSU as well? 😀
(And nice attempt to spell VOGONS with the keyboard keys 🤣 ).
Ooohh, the pain......
Reply 10 of 39, by brad1982_5
Cheers! 😀 Oh yes the PSU has been cleaned. Although not opened. Did my best not to make the fan spin too much with the air gun. All the components on the board and inside the PSU look fine. 😀
Reply 12 of 39, by brad1982_5
keropi wrote:
an excellent restoration! enjoy!
Certainly will! 😀 Cheers!
Reply 13 of 39, by PeterLI
Beatiful! Have fun! 😀
Reply 14 of 39, by 2fort5r
Very nice. Are you going to put OS/2 on it?
Account retired. Now posting as Errius.
Reply 15 of 39, by brad1982_5
Cheers guys! 😀 Not sure if I wish to put OS/2 never thought about that. I don't own a copy of OS/2.
More hardware changes. I have added a Ethernet adapter. I have changed the memory. And added cache memory which is 128KB
That is the maximum that the Aptiva can take.
But I have pinched the 128KB cache from my PVI-486SP3 which is now cacheless! :-0
I will try to get 128KB or even 256KB/512KB cache for my PVI-486SP3. It would be a double advantage of having 128KB for the Aptiva in the first place and hopefully having the chance to upgrade the cache in the PVI-486SP3 😀
Reply 16 of 39, by chinny22
Nice, Think hardware wise that's the IBM complete?
Like the idea of now maxing out the PVI-486, got to love when things fall together like that.
Reply 17 of 39, by brad1982_5
Yep I think the IBM hardware upgrades are complete. It now has 2x 8MB 60ns fastpage ram and changed the HDD to a seagate 1.2GB and cloned the old drive over so I do what I wish without loosing any of the original Aptiva software. I do have a AMD DX4 100 MHz CPU however it's 3.3V and I think the Intel DX2 66 MHz is 5V. The DX4 may run fine but I think the L1 cache could get fried overtime. There is no voltage setting that I can see on the mainboard. I do have 2x AMD X5 133 CPU's that could work in my ASUS VL/I-486SVGOX4 & ASUS PVI-486SP3 but both requires BIOS flashing I'm not prepared to take that risk as flashing the BIOS on 486s can not be as straight forward so I'm leaving them the way they are and also happy with the IBM with the DX2 66. 😀
I've got 256KB cache on the way though 😀 I've chosen 32k8*8 combination.
Reply 18 of 39, by AlphaDangerDen
I'm guessing that keyboard uses buckling spring switches?
Reply 19 of 39, by brad1982_5
Yes it has buckling spring switches. I'm using this keyboard right now on my main rig. It is the Model M2 which has the same buckling switches as the original Model M. The keyboard does not quite have the weight and build quality of the original model M but it's still a pretty nice keyboard. 😀
