First post, by pete8475
Specs:
Asus CUBX
Intel Tualatin Celeron 1.3 running at 1495 mhz (used to run this at 1612 mhz but it was never quite stable enough)
Geforce 6200 256MB PCI Video Card
1024MB PC-133 SD-RAM (4x256)
Seagate 250GB HD
Promise Ultra 133 (CMD ata66 controller on the MB is a turd)
Sound Blaster Audigy 2 ZS
3.5" Mitsumi Floppy
Realtek 10/100 NIC
Lite-ON DVD-RW and LG DVD-ROM
USB 2.0 PCI Card (connected to front ports)
XP / 98SE dual boot
This might be my favorite PC, I've been playing around with this board since shortly after it was released, I upgraded from a Pentium 233MMX to this board with a Celeron 466 and a whopping 128MB of ram. Ahhh those were the days. 🤣
I might swap out that black LG drive for a white Lite-On that I just took out of my AMD system.
The eagle eyed viewer may notice that's an AGP card in there at the moment, I'm currently staying up too late not doing my taxes when I should and running various benchmarks comparing an FX5200 AGP to the 6200 PCI card I have. So far the FX is a bit quicker in Quake 3 at the same settings. I might also toss in my old Hercules 3D Prophet 4500 64MB (PowerVR Kyro II) to see how that baby does.
    1.19 MiB
    1.11 MiB
    1.51 MiB
Reply 1 of 14, by pete8475
Benchmark results with the CPU running at 1495 mhz:
3dmark2001SE (1024x768 - default settings)
2242 - Kyro II 64MB
4091 - Geforce FX5200 128MB
5225 - Geforce 6200 256MB
3dmark2000 (1024x768 - default settings)
4450 - Kyro II 64MB
6011 - Geforce FX5200 128MB
6621 - Geforce 6200 256MB
Quake 3 (1024x768x16 - highest quality, trilinear filtering)
96.0 fps - Geforce FX5200 128MB
88.6 fps - Geforce 6200 256MB
The Kyro II refused to run Quake 3, I have no idea why I'm sure I used to play that game all the time on that card. It's fan is making a horrible screech these days so I quickly pulled it out after running the 3dmark programs.
I also tossed in a 32MB Matrox G450 and it refused to run anything. 😕
In the end I'm back to using the Geforce 6200 PCI card. The FX5200 is probably a bit quicker in actual games but the 6200 seems to have better 2d image quality on my old Lenovo LCD. There's some weird ghosting on the edges of some stuff with the FX5200. Also the heatsink on the FX5200 gets ridiculously hot.
EDIT - I also ended up switching out the black drive for the white one.
    115.16 KiB
    720.87 KiB
    505.25 KiB
Reply 3 of 14, by pete8475
pete8475 wrote:
Maybe I'm weird but today I ordered an FX5700 LE 256mb card on ebay. Hopefully it shows up soon.
The FX5700 has yet to show up, however I did pick up a Geforce 3 TI500 locally today.
I missed that generation of cards when they were new, so it should be interesting to see how it does compared to the other cards I have that work with this machine.
EDIT - The TI500 has 64mb of memory and beats the other cards I have in 3dMark 2000 and 2001.
Results:
Quake 3 - 108fps
3dMark2000 - 7192
3dMark2001SE - 6267
The TI500 came in an old Dell Pentium 4 desktop that I bought today for $50. I might buy a 3.06ghz P4 off Ebay and have myself a decent P4 machine too. I always wanted one of those HT P4's when they were new.
    691.29 KiB
Reply 4 of 14, by bofh.fromhell
"Fun" fact, the ATI radeon 9xxx series coolers might fit that FX so well you will keep sorting it with ATI cards until you wise up and put a sticker on it saying what it is =)
Mine identifies as an FX5700v, whatever that means, the Techpowerup DB has nothing on that.
It's a great card tho, and quiet with the ATI HSF.
Reply 5 of 14, by pete8475
bofh.fromhell wrote:
"Fun" fact, the ATI radeon 9xxx series coolers might fit that FX so well you will keep sorting it with ATI cards until you wise […]
hah! I might even have one of those ATI coolers in one of my junk boxes.
Reply 6 of 14, by bofh.fromhell
And I'm sure the ATI cooler is superior in every single way compared to the junk HSF's they put on theese cards from new =)
Got a bunch of them from my hunt for a working 9800PRO, man those cards seems to be rare nowadays.
And I swear, more then once have I installed it and then tried to install ATI drivers 🤣.
Reply 7 of 14, by pete8475
Awesome. I went through my various "Box O' Junk™" boxes and didn't find one. I'm sure I had a few, having owned a 9700 and 9800 Pro that I put Zalman coolers on over the years.
Ah well, I think I might buy another gigantic fanless Zalman on ebay or maybe one of those dirt cheap vga coolers from China just to see what I get. The fan on the FX5700 is noisy as hell.
Reply 8 of 14, by pete8475
The FX5700LE arrived today and I ran the same benchmarks I usually do to get these numbers:
FX5700LE:
Quake 3 - 106.5fps
3dMark2000 - 7116
3dMark2001SE - 6702
GF3TI500 64MB:
Quake 3 - 108fps
3dMark2000 - 7192
3dMark2001SE - 6267
    907.11 KiB
    497.76 KiB
Reply 9 of 14, by bofh.fromhell
If that fan is noisy you can get brand new ones:
https://www.ebay.com/itm/NVIDIA-Fan-NV-1017-1 … b0AAMXQ0v1RZuKs
And yea, you need newer games to see some benefit from the FX =)
Still, its a decent card with low powerdraw.
And I much prefer to use a card with almost no retro value when i fiddle around with my stuff =)
Reply 10 of 14, by pete8475
If that fan is noisy you can get brand new ones: https://www.ebay.com/itm/NVIDIA-Fan-NV-1017-1 … b0AAMXQ0v1RZuKs […]
I might get one of those just to have on hand. Last night I ordered a Zalman ZM80C-HP to use with the card though.
Reply 11 of 14, by blank001
Great system. You don't see enough CUB-X setups as most of the attention is on the P3B-F. It's a better board than the P3B-F; much better / faster CPU options for example (as you've shown). I think there even 2 ISA versions floating about.
That said, I think you want to really be using the ISA to prefer it over the CUSL-2 or TUSL-2.
Ah, and lastly, I love the ti500. Great touch.
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 12 of 14, by pete8475
Thanks.
The CUBX has been temporarily retired though, it decided to stop posting consistently last week and I tried different RAM, video cards, power supplies, etc and no luck. Pulled the CPU and it works fine in a micro-atx via chipset board I have that officially supports Tualatin processors so it's probably not the issue. I'm thinking about picking up a TUV4X board on ebay and replacing it with that. Right now though I'm sidetracked with a 3.06ghz Northwood P4 and P4C-800E Deluxe that I just put together.
Reply 13 of 14, by canthearu
Try explicitly setting 60hz refresh rates on the FX5200. LCD monitors can often lock on better and cards produce a sharper output at 60hz vs the default optimal setting.
Reply 14 of 14, by pete8475
Good advice, however I had already done that with no noticeable improvement (at least to my eyes).
All that said the CUBX has been retired for now and I've been using a Pentium 4 with a Geforce 3 TI500 as my main old games machine lately.
