Reply 240 of 325, by Anonymous Coward
- l33t
Doesn't cachechk report the amount of cacheable RAM?
I get these with everything at 0WS
I don't see me bothering with this mobo anymore, I can't get UMBs to work. Although I set the free regions as R/W Shadow (or vacant) in MR-BIOS , TLB just hangs on initialization just like they are still write-protected or something...
I think it is CTCM7 that reports the amount of cacheable RAM.
I think you're right, I confused them.
I'm late to the party, but here's my 386SX25 with VLSI SCAMPSX chipset (from this motherboard 80386 BIOS image collection)
This one actually has a really cool bios that lets you tweak settings like RAM waitstates, by how much you want to divide the CPU speed when turbo is enabled (1,2,3 or 4), and other things.
With the most optimized settings, here's the score I get :
It scores at 55 in topbench.
I also fixed this motherboard recently which actually uses the exact same chipset, but comes with a SX33 😁
The BIOS is way less permissive ... But wait a minute, what if I just put the bios from the other motherboard in this one instead ?
You guessed it, it worked flawlessly 😁 (sorry, no clean screenshot this time, it was just a quick test)
It scores at 60 in topbench. The smaller gap in topbench is explained by the integrated OAK video card which kinda sucks.
Also, it scores almost equally to my 386DX 40 🤣 (though probably the FPU is making the score of the DX40 way lower than it should)
So, with a good BIOS, the VLSI scampsx chipset seems very cool 😁
Your SX doesn't have the FPU installed. The DX does. It skews the speedsys results.
Yeah I noticed that. With a fpu installed, the sx25 falls back to 3.70 or something like that. Which is still nice I guess
Here's my Am386DX-40 on a Seritech SER-386ADIII with 8mb of 70ns ram and a Genoa 7900 (ET4000AX).
So I just decided to run speedsys on my newly built 386
Ive read that the numeric processor gives you much lower results at around half of what it should be, and even disabling it in the BIOS doesnt seem to fool speedsys into not detecting the NPU.
I guess these results are fairly typical, but my main concern was the linear read speed that seems rather low compared to what others are getting.
It told me I had to disable smartdrive and 386 memory management which I did, my first test with smartdrive enabled did give be a slightly higher linear read speed from the HDD, but nothing to speak of.
Specs:
AMD 386 DX40
ASUS ISA-386U3
Seagate Medallist 520MB HDD
Cheap trident card while testing
16MB 70ns RAM
64KB of cache (soon to upgrade to 256KB)
IIT 3C87-40 NPU
You have it backwards. The CPU score with the FPU is what is should be. The score is inflated when the FPU is absent. It's just shitty programming.
Perhaps the memory score is a tad slow. What are you timings set like in the BIOS?
Anonymous Coward wrote on 2020-08-07, 05:15:You have it backwards. The CPU score with the FPU is what is should be. The score is inflated when the FPU is absent. It's just shitty programming.
Oh, I see.
I was looking at the likes of memory throughput and bandwidth, other sores posted here (without the FPU) appear to be at least double or more of the score I got, even with a DX-25 CPU.
Its too hard to pull out the chip now that its in the case to do another benchmark with it removed.
As far as memory timings, I have no idea what they are, the BIOS has shitty options, I only can set the cache to "fast" or "slow"
Obviously ive got it set to fast, but its only 20ns memory and im hoping the 15ns memory I drop in will be faster.
I hope to experiment with some newer BIOS images, including a MR BIOS ROM that is supposed to have way more options regarding timings, etc.
For an Asus board, it has a strangely limited BIOS. MR-BIOS upgrade is a great idea.
Simply dumping in 15ns SRAMs won't change anything. You have to be able to tighten cache timings in order to see a difference. Even then, I find that with 20ns cache I can usually do 2-1-1-1 memory timings on a 40mhz 386. Upgrading probably isn't worth it unless you want to have a dab at 50MHz bus.
Anonymous Coward wrote on 2020-08-07, 08:54:For an Asus board, it has a strangely limited BIOS. MR-BIOS upgrade is a great idea.
OK, well I want to upgrade it to 256KB, and ive got some 15ns chips hanging around, but have plenty of 20ns, if im not going to notice any difference.
Would this affect my memory bandwith results if i can get the timings down?
There are separate adjustments for cache and RAM timings. In theory you should be able to increase bandwidth. On a 40MHz 386 board, about 30MB/sec is normal for cache, and 20MB/sec for DRAM, so you certainly have a little room for improvement.
Ok, it will be interesting to see what improvements the other BIOS can provide.
Whats the difference between bandwidth and throughput?
The last results shared before mine say about 60MB/s bandwidth.
Mine is much lower.
I would think bandwidth would be the maximum transfer rate of the bus, and throughput is the actual rate the data moves over the bus. With speedsys, who really knows though.
PCBell model LA333CSB, NOT PackardBell
TMC Research Corporation PAT38PX v3.10
386DX 33
64KB cache
OPTi 82C392
8MB
Trident TVGA 9000A
One question, why does speedsys seem to think all our motherboards have the Y2K bug?
Ti 486 SXL-40
Ser 386-AD3 (ALi M1429) motherboard
8 MB RAM
