It is nice to see that (finally) more retro enthusiasts are experimenting with 1024 KB of cache. Once you get your pieces installed and properly jumpered, can you verify using CTCM7 that all your RAM is being cached? For example, if using 1024 KB of cache in write-back mode, that 128 MB of RAM is really being cached?
Booting into Windows 98 and running a few benchmarks, preferably Ziff-Davis CPUMark99 v1.0, could also be used as an indicator for all the RAM being cached. From the Ultimate 486 Benchmark Comparison (U4BC), Appendix 2, Colums A-V, you can match up which CPU you are using, and if all your RAM is cached, your CPUMark99 scores (row 57) should be ~50% greater than those found in Columns A-V. Note that you need to be using the fastest possible cache and memory timings for this to be a fairer comparison.
Unfortunately, I didn't have all the RAM cached when I did the U4BC, but test 57 is really the only test that was significantly affected by this. A typical example of a partially cached score was 3.82 for a Cyrix 5x86-133. This want up to 5.55 for a fully cached score. Note that colums A*, B*, and C* are fully-cached.
Thanks.
