Reply 20 of 25, by Mau1wurf1977
- l33t++
That initial build must have been a classic combination back in the day. So many had a 6600GT, what a great card.
wrote:Just found a Point of View GeForce 6800GT 256MB in the dumpster in good working order. Not sure, if I'm gonna use it because the noise coming from its fan is awful! What's interesting to me is that it has two molex connectors for power.
Also found a case for this build so stay tuned for pics 😉
Not surprising to see twin molex on a 6800GT - that's how the 6800 Ultra was generally set up, and some manufacturers re-used the same PCBs for 6800GTs. It may have better overclocking potential than the "average" 6800GT as a result of the second connector. As far as cooling - I know the Zalman VF-700AlCu worked well for my 6800GT, and was very quiet.
To post inline use the [img] tag.
On the card - looks like the sink was broken off at the pins; here's roughly what it should look like: http://content.hwigroup.net/images/products/x … rce_6800_gt.jpg (pulled it out of inline because its HUGE)
You might be able to use small generic BGA/FET sinks to replace it. 😀
Just installed everything in this case today. No hard drive at the moment as I ended up using that 320GB laptop drive for my main PC. My system disk decided to kick the bucket overnight and I needed a replacement quick.
Notes:
That Core2Duo sticker has to go as well as the one next to it. Power supply could also be better - LC Power isn't exactly famous for reliability.
