First post, by Dwaco
Pics!
What it has
- Single Pentium ||| 600EB CPU
- 256 MB SDRAM
- - Voodoo3 3000
- - Sound Blaster Audigy EX
- - DVD-RAM Drive
- - Adaptec 29160
- - Two SCA disk cages
History of the workstation
I think I should be the original owner. Frankly, I don't remember by now!
I remember the moment of stopping using it as a a daily driver when I got my next one.
The list of PCs I owned 199X-200X:
- Some locally prebuilt 486-DX50
- HP Vectra MT 5/133, where most likely I have put a Voodoo1 and then replaced with Voodoo2 later
- HP Kayak XU800 (this one)
- ... and then first machine I have put together myself - P4 with P4P800 Asus MOBO
When XU800 stopped being my daily driver, I still kept it. It was so nice looking! Something was preparing me
for my retro hobby eventually which started about couple of years ago.
- Original model was supposed to have 15Gb hard disk. Mine had 20 when I started fiddling with the machine now. No idea how did it happen.
- Guess I should have originally put Voodoo3 3000 into it back 1999. No idea again what did I do with Matrox Millenium that should have been inside.
How special is this workstation
- With this model (alongside Kayak XM600) HP decided to transition PC workstations
to full tower from minitower (Kayak XU and XW Penitum III machines) and minitower-on-pedestal (Xeon versions)
Slot 2 size problems and thermals perhaps.
New beginning for HP PC workstations! - UltraFlow air flow guide to use exhaust fan to cool the CPU(s) heatsinks. There is no CPU fan on heatsink
(at least for SKUs I have documentation for, which is max 866 MHz, there were SKUs up to 1GHz). Motherboard
has CPU fan headers though. - RAM is located on a special daughter board. And there are two separate versions for it - SDRAM and RDRAM. Actually later it turned out that ECC implementation in chipset was broken so HP said to contact them to switch to rambus back then. I completely missed that.
- Separate thermal zones for upper part (CPU/RAM) and lower part (AGP/PCI/PCI64 slots)
- Upper thermal zone (originally) is negative pressure, lower thermal zone (originally) has positive pressure.
- The case created for is the last case HP produced with MaxiLife LCD screen for system health.
It even works when the system is powered down with power plug connected!
What is suboptimal
- Front bezel is designed to be just over ther 5.25 drive cages a little, so cannot pull drive cages without removing it
first (which is toolless but requires removing side panel) - It is difficult power down using the front panel button. If press for too little, it doesn't power down,
too much and it could restart instead. - 12V rail voltage is in 11.6V-11.7V range according to MB and SCA cages sensers which is a little concerning.
It doesn't seem I overload PSU though looking at docs. - No ISA slots. This workstation was so forward-looking though, this wasn't the concern back then!
What did I do with this machine now
- Thermaltake SL1 exhaust to cool Voodoo3 3000
- Both original DVD-ROM and DVD-RW I had in there died, so replaced with SCSI DVD-RAM drive with caddy
- PCI 64-bit Adaptec 29160, for now used to drive DVD-RAM. Overkill for sure, but where else would I put a 64-bit PCI SCSI card?
- Couple of SCA drive cages, as I have gotten a bunch of 10k and 15k RPM SCA disks
- Rear exhaust fan replaced with Noctua
I am mostly tweaking the hardware now, but eventually will have a go at some game CDs I've had lying around as well as development
tools I was using back then (like Borland C++).
PC: HP Kayak XU800 [2x PIII 1Ghz, 512 Mb RAM, Voodoo3 3000, SB Audigy Platinum EX]
Sparc: Blade 1000 [2x US-III, 3Gb RAM, 2x 73Gb FC-AL 10k, XVR-1000], Blade 100
PA-RISC: HP C3750 [FX10Pro]
Sony F1XDJ, A1200, C128
