Retro Rig Photo Thread
Reply 2400 of 2713, by hydroksyde
Currently most of my retro collection is in a storage unit in another part of the country, but here's something I put together recently
Pentium III 800Mhz (133Mhz FSB version)
256MB SDRAM
8GB CF Card
GeforceFX 5200
40X CD-ROM
Had a Voodoo2 12MB installed but removed it for another build, hence the background
Philips 170B LCD
"Technica" two way speaker systems with Class D amplifier (the perspex thing)
Got plans to add a Voodoo3 3000 to this but this is a start!
Reply 2401 of 2713, by Chadti99
Obijuan1983 wrote on 2022-09-10, 23:39:
Intel DX4 100MHz Build […]
finished!
Nice build! What’s the motherboard brand/model in this one? Does it accept 1024k cache?
Reply 2402 of 2713, by pixelatedscraps
rcarkk wrote on 2022-12-08, 12:30:
More pictures...
Great cable routing and pics. I wish Vogons allowed likes 😉
My ultimate dual 440LX / Voodoo2 SLI build
Reply 2403 of 2713, by rcarkk
pixelatedscraps wrote on 2022-12-23, 21:57:
More pictures...
Thank you. The huge majority of retro builders, don´t bother to cable manage. I would love to see more people trying the best they can in that regard.
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
PC Remake - Pentium III 450 + Matrox G400 16MB
The K6-III build
Reply 2404 of 2713, by devius
rcarkk wrote on 2022-12-24, 14:24:
...I would love to see more people trying the best they can in that regard.
So, my concern is in regards to flat cables, like IDE cables. When you bend them really tight, like you seem to be doing, doesn't that potentially damage the cable? That is, I assume that as long as it stays put no harm will come, but if you need to use it on another system and do more tight bends won't the stress cause the wires to break?
Reply 2405 of 2713, by Obijuan1983
Chadti99 wrote on 2022-12-20, 09:45:
finished!
Its Aopen/Acer AP43 , it accepts 1MB cache
Reply 2406 of 2713, by rcarkk
devius wrote on 2022-12-24, 14:31:
You can do a fair number of IDE cable bending in the same place with no problem. The cables don´t brake easily.
The K6-III build
Reply 2407 of 2713, by DaveDDS
You can see almost all of my "retro" systems at "Daves Old Computers".
Lots of pics and description. In the process of downsizing and moving to
a more suitable location, I've passed most of these on to new homes...
But here are couple which are NOT on the site:
As part of above mentioned downsizing, I passed on my original "ImageDisk"
system... but enough people have wanted me to continue supporting IMD, that
I threw together this little replacement. Things to note:
- I still had a second AOPEN mainboard with the same "really good" floppy controller.
- I didn't have any spare "old style" cases, and I wanted it to take up as little space as possible.
- Note floppy cable, the "twist" is around the middle set of connectors..
This lets me put any drive B: at the much more accessible end of the cable.
Another one I just acquired... the smallest DOS system I've ever had (wouldn't
surprise me it it were the smallest ever made) - note SD card for size.
Dave Dunfield - https://dunfield.themindfactory.com
    48.34 KiB
    141.91 KiB
Reply 2408 of 2713, by devius
On the 31st of December 1994 I unboxed my first PC. It was a Compaq Presario CDS 510 with the CPU upgraded to a DX2 66MHz.
Today, exactly 28 years later, I finally finished cleaning and restoring to factory settings this Presario CDS 524. Not exactly the same, but close enough. It's practically original except I replaced the original 420MB HDD with a 2GB Compact Flash and added a 3Com ethernet card.
Specs:
  • Intel 486 DX2 66MHz
  • 8MB RAM
  • Cirrus Logic CL-GD5424 with 512KB
  • 2GB Compact Flash
  • 4X CD-ROM
  • ESS AudioDrive ES688
  • Built-in stereo speakers
  • Built-in 14" monitor
736.47 KiB
Compaq Presario CDS 524 running Hexen
GPL-2.0-or-later
Reply 2409 of 2713, by kolderman
devius wrote on 2022-12-31, 21:53:
On the 31st of December 1994 I unboxed my first PC. It was a Compaq Presario CDS 510 with the CPU upgraded to a DX2 66MHz. […]
Specs:
  • 8MB RAM
  • 2GB Compact Flash
  • 4X CD-ROM
Perfection.
Reply 2410 of 2713, by b0by007
Hi people. This is my retro collection.
838.82 KiB
retro collection
From left to right:
1. Deck mid tower - Pentium 166 MMX, 48mb ram, mb LuckyStar 5v1a, video ali m3147, sound yamaha YMF719E-S, 80gb sata hdd reduced to 8gb due to old bios (sata-to-ide adapter), win95
2. IBM PC 330 - Pentium 166, 64mb ram, video integrated S3 Trio864, sound Crystal CX4235, 80gb sata hdd (sata-to-ide adapter), win98se
3. Fujitsu ICL EgoPro x450 - Pentium 90, 32mb ram, video integrated Ati M64, sound ESS audiodrive es688F, 1 gb cf - it worked, but now it just beeps with no video output.
4. Fujitsu Siemens D1561-C23 GS 3 - Pentium 4 3,2ghz, 512mb ram, video Geforce FX5200, sound C-Media CMI 87386 chb 5.1ch-1014, 160 sata hdd, win98se (full drivers for win98se still available on fujitsu site - kudos)
5. HP T5720 thinclient - AMD Geode NX 1500 CPU=1GHz, 512mb ram, Video SiS741 GX Integrated, sound SiS 7012 integrated, 4gb dom, win98se (thanks PhilsComputerlab for all drivers)
6. Fujitsu FUTRO B210 thinclient- VIA C3 samuel 2 533mhz, 64mb ram, video S3 ProSavage integrated, sound VIA VT8231 integrated (thanks Jazefox for VIASBCFG), 2gb dom, ms-dos 6.22
7. HP T5530 thinclient - VIA Eden 800mhz, 128mb ram, video VIA S3G Unichrome Pro IGP integrated, sound - VIA VT8237 AC'97 (Vinyl_V700b drivers), 4gb dom, win98se
The Display is a Dell Panel Monitor 1707 FPt, 4:3 aspect ratio, 1280x1024 max resolution.
Last year I got inspired into retro pc/gaming when I saw philscomputerlab retrofitting those HP thinclients into dos/win98se pcs. I have those thinclients since 2010, used them as file servers, print servers, internet radio player etc.
I dug up from storage that Deck mid-tower (used as router back in the day when internet speed was 256kbs) and Fujitsu ICL ErgoPro (used as mp3 player back in the day).
I got for free from a friend the Dell Display with the Fujitsu Siemens P4.
The only one I bought was the IBM pc 330 because I really like this sliding case and it was a too good price to miss.
Some need front cleaning but it is a hobby and my free time is soo limited. I am kinda sad that I broke that Fujitsu ICL ErgoPro (installed the wrong way a CF to IDE adapter), but still have some hope for repair since is not completly dead, it makes some long and strange beeps, like is trying to sing.
HP Vectra D2753A 486/25N i486 SX 25mhz
UNISYS SG3500 AMD486 DX2 66mhz
OLIVETTI M4 i486 SX2 50mhz
IBM PC 330 6577-79T, Pentium 166mhz
IBM PC 300GL 6561-350, Pentium II MMX 266mhz
My retro youtube channel!
Reply 2411 of 2713, by pampilhoso
Specs:
  • 8MB RAM
  • 2GB Compact Flash
  • 4X CD-ROM
Hi fellow national,
Exactly my story.. first computer, 1994. Version CDS 520 the one with an AMD SX2 66mhz.
Now it features an evergreen 5x86 133mhz, 64 ram, CF card, AWE 64 gold.
237.86 KiB
I don't know if you are already in it but here's a dedicated group for the CDS:
https://www.facebook.com/groups/compaqpresariocds500series
Reply 2412 of 2713, by Dae
b0by007 wrote on 2023-01-03, 21:57:
Hey, does sound work correctly on that in dos games? There seems to be a drver for the SIS 7012 for win98se. I suppose you haven't tried any PCI video card in it? Am also thinking about getting one if it's worth while.
Reply 2413 of 2713, by b0by007
It is a very nice thinclient. Sound works correctly for duke3d, doom, prehistorik 2 and others.
I didnt tried many games (dos or windows) because I thinker a lot on those pentium I systems with different configs - storage/ OS...
I haven't tried any pci video or sound cards in it, because I need to get an extension pci cable or pci riser and those are getting rare and too expensive these days.
I got all drivers from PhilsComputerlab. There is an article and some videos about this cool machine:
https://www.philscomputerlab.com/hp-t5720.html
Reply 2414 of 2713, by eesz34
From all new parts I've been collecting, except the hard drive isn't new.
486DX-33, 16MB RAM, GD5428 VLB, OPti sound, 10mbps NIC, Techmedia 3.5, Teac 5.25, CDROM, and "Monster Floppy" controller for the 3rd drive, the Gotek.
MR BIOS so all three floppy drives can be booted from, and natively supported in DOS (my favorite part).
Reply 2415 of 2713, by tuoasm
Abit BE6-II
Katmai 600MHz
256MB PC133
Asus V7700 GF2 GTS
Diamond Monster Sound MX300
2x 15GB HDD
FSP 235W PSU
Fujitsu ErgoPro eL case
Had this case and most of these parts since 99
    1.64 MiB
    1.53 MiB
Reply 2416 of 2713, by bofh.fromhell
tuoasm wrote on 2023-02-28, 11:45:
Abit BE6-II v1.0 Katmai 600MHz 256MB PC133 Asus V7700 GF2 GTS Diamond Monster Sound MX300 2x 15GB HDD FSP 235W PSU Fujitsu Erg […]
Abit BE6-II v1.0
Katmai 600MHz
256MB PC133
Asus V7700 GF2 GTS
2x 15GB HDD
FSP 235W PSU
Sweet period appropriate rig.
Anything with an Abit is a thumbs up from me =)
And its Y2K compliant!
Reply 2417 of 2713, by Unofficial Ghost
Still want to add a couple of things, and there's always room for more stickers, but here's my Windows 98 SE build so far.
Specs are:
AsRock P4i65G
Pentium 4 2.66Ghz,
GeForce FX 5900 XT
SB Audigy 2 ZS
512MB RAM
21" iiyama CRT
Added some modern upgrades such as: Noctua fans, Startech CPU Cooler, 128GB SSD (loaded into a hot swap 3.5" bay) & a Seasonic 550W PSU.
And recently picked up an Artic NV Silencer 3 cooler for the GPU... good bit of kit & a breath of fresh air compared to the noisy stock fan!
Other stuff: Denon PMA-450 amp + Acoustic Research AR18s speakers (games/music etc sound amazing on these 8" beasts!! 😀)
    1.12 MiB
    1.19 MiB
    913.24 KiB
    1.29 MiB
Reply 2418 of 2713, by psychofox
Unofficial Ghost wrote on 2023-03-06, 16:20:
That custom sticker idea looks cool, will do that on one of my systems too.
Reply 2419 of 2713, by PD2JK
Best sticker 😉
292.8 KiB
