Also I'd like to give you a quick peek at this one:
Digital Multia
Some quick specs:
CPU: Pentium 133MHz (came original with a P100 iirc)
RAM: 16MB (2*8)
HDD: 1GB solid state drive (compact flash?)
SCSI controller: NCR C810 (not in use)
FDD: 1.44MB (laptop style)
Video: S3 Vision 968 PCI (on-board)
Audio: Ad Lib Gold compatible OPL3
Network: DEC 21040
For such a small form factor it is quite well equipped and it makes a nice DOS retro gaming station. Don't expect to much upgrading possibilities. Though the case has space for e.g. an expansion card, there is no riser where to connect it to.
This particular machine works very well. Only issue it has is the connection between the power switch of the housing and the switch on the PSU itself. The glue which hold these two together is degraded and just fell off. Have to repair that. Besides that it is a little dirty. I didn't plan to make a post about it on Vogons but came around it while searching for some other computer parts in the attic. I don't know if these ones are rare or not. For some years I saw never one for sale, but the last year I spotted at least 5 pieces of various sellers.
Now then, time for some visuals!
