First post, by ProfessorProfessorson
- Member
So anyway, ended up picking up a large socket A tower for 10 bucks the other day to use for another socket A build. Had to do a massive clean up job on everything inside and out. Had a Gigabyte 7VAXP motherboard installed. A review of the board can be seen here: http://www.anandtech.com/show/1007/2 .
The board was acting flaky initially, then refused to power up all together after a couple hrs, so I baked it. After 10 mins in the oven to do a reflow, and also swapped out the original north bridge cooler for a custom one I wanted to use instead, with some Arctic Silver applied. Now it works perfect. also had to remove the Antec 300 watt that was in it, as it had a cap that was buldging. I may fix the psu later, do a cap job on it, but for now, I stuck in a Dell 300 watt. The case had 3 fans. One was in the harddrive bay, and had totally seized. I took it apart completely, re-oiled it, now it works perfect. The other two fans worked fine, but I re-oiled them regardless.
The cpu in it was originally a XP2100+, which I removed and swapped out with a faster Sempron 2400+. The gpu installed originally was a R9600 XT. Again, swapped out for my faster 5950 Ultra. Installed a Sb Audegy SE and disabled the onboard audio. May mess with the raid function later, but for right now, just using the 120gb drive that was in it originally. The extra USB bracket was included, but I removed it to free up room in the case, choosing to just leave the original audio and firewire ones in place. Anyway, the thing gets almost 12k in 3dMark 01 at default, and about 10k almost in 1600x1200.
Yeah, coulda just stuck a faster P4 board in or whatever, I have other stuff laying around and all, but I really just wanted another Socket A system going. For that matter, coulda used a diff Socket A board, as I have a few, but I was really die hard on saving this Gigabyte one.
Out of curiosity, does anyone have any idea what case this is that this build used? I know its a Antec, but I was wondering which model specifically.
