775i65G AGP beast
First post, by swaaye
I've been working on this machine for a few months. I've tried a few different CPUs and found that it's best to stick to 800 MT/s FSB if you want the board to work really well.
The goal with this build is to have the fastest AGP setup possible for experimentation and for making goofy Youtube videos (as I've done with the GeForce 5900 Ultra and Radeon 8500).
ASRock 775i65G (865G AGP SATA) (BIOS 3.2+ for Wolfdale)
Pentium Dual Core E5700 3.0 GHz (Wolfdale-2M, 800 MT/s FSB)
Scythe Ninja Plus CPU cooler (:D Wolfdale barely heats this up even without a fan)
2GB PC3200 CAS 2.5 (must be CL2.5)
640GB WD + 160GB WD
Audigy Platinum
Radeon 9800 Pro 256MB
Intel Pro 1000GT NIC
Random DVDROM
600W OCZ Gamexstream
Gateway P4 Willamette case
This board works perfectly with my OCZ Vertex 2 SSD too, but I wanted to use that drive elsewhere.
Reply 1 of 60, by BigBodZod
Very nice, but didn't you have a couple of old WD Raptor 36GB or 74GB drives lying about for testing 😉
That would have been fun to try out.
No matter where you go, there you are...
Reply 2 of 60, by sgt76
Beastly, beastly, beastly. This is very similar to my first C2D rig 4 years ago so I like everything bout it. Nice touches with the Ninja and the case. Looks "industrial strength".
Reply 3 of 60, by swaaye
It amazes me how the RAM chips on that 9800 Pro 256MB are too hot to hold my fingers on even with RAMsinks.
I sold off a Velociraptor 150GB a couple of months ago. I figured it was time to sell it before it's worthless. 😁
VR150 is very quiet though believe it or not. It supports AAM. The older, big Raptors are rocks in a blender and I avoid that now. Especially when I can just get a SSD!
Reply 4 of 60, by prophase_j
Yeah these asrock boards are nuts. I have had good results at 1066mhz... i mean it's not rock stable but will certainly last through some benchmarks and some gaming. It takes a couple days to freeze, at least in my experience. I obtained some high spec ram that let me run the memory divider 1:1 at 1066FSB, and before that I was running 2:3 with 1100FSB+
Are you using the beta bios 3.22? On that one it will let you set CAS 3 and get more flexibility, haven't tried it out myself though, I had better ram before I had the E5800 that necessitated it because of it's fractional multiplier.
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Reply 5 of 60, by swaaye
I tried a Core 2 Extreme X6800 in it. 2.93 GHz, 1066 FSB. The board would freeze at various points during POST until it had warmed up for about 5 mins. I tried all sorts of things, including BIOS settings, diff RAM, diff video cards and even cleaned the CPU pads. BIOS v3.20 and v3.30.
Besides, with this board and chipset, RAM ratios cause problems. With a 1066 FSB CPU, the BIOS locks to the 3:2 ratio, meaning your PC3200 is at around 177 MHz. A 800 FSB CPU allows 1:1 ratio. There's no advantage to a 1066 FSB.
IMO, the best CPU is one from the Pentium E5x00 family. High clock speed, Wolfdale, 800 FSB, and an adequate 2MB L2.
Reply 6 of 60, by jaqie
/me snrks.
You sure about that?
Reply 7 of 60, by swaaye
Yup on this board I'm sure there's no advantage to 1066 over 800. You end up with less memory bandwidth because of how the BIOS locks you to 176 MHz RAM clock. With a real Core 2 chipset, designed for 1066+ MT/s FSB, where you have DDR2/3 that can run 1:1 or better, it's another story.
Reply 8 of 60, by prophase_j
It's not locked, just have to have some good ram 😀
"Retro Rocket"
Reply 9 of 60, by swaaye
No, it is truly locked. 😀 The DRAM speed selection in the BIOS is greyed out and can not be changed when a 1066 MT/s CPU is installed. It locks to the 133 MHz RAM setting (3:2 ratio). I believe even manually lowering FSB does not change this. It's very annoying of course.
With a 800 MT/s CPU installed, the BIOS allows you to select any ratio.
Those tricky Asrock BIOS programmers did some annoying things. It's also impossible to set the multiplier of a Extreme edition CPU. It remains greyed out. So you have to resort to Windows utilities. And there is no CPU voltage (maybe for the best, considering the VRM here).
Reply 10 of 60, by BigBodZod
See, I still have 4 of these bricks lying about, a pair of 36GB and a pair of 74GB Raptors.
They were decent drives but hot and noisy to some degree yes 😉
As for the fact you can get a decent SSD then yes, that is a good sub for one of these drives.
Reply 11 of 60, by prophase_j
swaaye wrote:
No, it is truly locked. :) The DRAM speed selection in the BIOS is greyed out and can not be changed when a 1066 MT/s CPU is in […]
Okay I think I understand better now. I have only had 800FSB in it so in that case I don't know. Wow.. I would find that incredibly annoying too.
With both my e2160 and the e5800 they are grey until I disable Speedstep in the bios.
"Retro Rocket"
Reply 12 of 60, by swaaye
I don't know if I tried that but that makes sense.
Well I sold that X6800 anyway, because it's worth about $110 and the RAM ratio being locked was a real showstopper for tweaking. The $50 E5700 seems flawlessly stable on the board.
I'm trying out a bunch of AGP cards. Radeon 8500 and 9800 Pro. Geforce 5200U and 5900U. It's interesting to see them run games when the CPU is definitely not a bottleneck.
The 775i65G does have another unfortunate issue, that being the lack of S3 sleep. It looks like S3 was available in early BIOSs but was removed because of problems.
Reply 13 of 60, by sgt76
Maybe a bit unrelated. But from my experiences with this board and my recent build which also involved buying a ton of parts from 06-08- cpus, mobos, etc, and the benefit of hindsight, I'm drawn to conclude that Core 2 is a very powerful architecture but running on motherboards that are antiquated, eg. only 4gb ram cacheable, 2 ram slots stable, finicky with modern O/Ss like Ubuntu, Win 7, quirky setups, etc.
The same generation AMD stuff, on the cpu front AM2 dual cores right up to Phenom 1 and chipsets from Nvidia 5xx to 790FX may have less clock for clock power (well, maybe not Ph1 but it clocks lower anyway) but seem to have more modern chipsets, easier to use, setup and overclock. To me at least, though this may be psychological, AMD systems seem more stable and smoother at the desktop.
Hmm if I were to describe it in automotive analogy it would be like Core 2 = driving an 80s rear wheel drive big engine Beemer (fast but on the edge oversteer happy handling) and AM2/2+ = new Golf GTi (maybe not as fast but easy, relaxed handling).
Reply 15 of 60, by Freckles
Hey guys, i'm also using the same board: here's a pic
HD4670
e6600 @ 2.6ghz
2x1gb PQI DDR400
RAID 0
i am looking for a modded bios so i can run CL3 - i want to buy a set of DDR500 - maybe someone can help ?
Reply 16 of 60, by Freckles
ps: how ghetto is my machine - don't you just love the electrical tape ? !! lulz : >
Reply 17 of 60, by swaaye
🤣 it looks nice enough to me.
I see you attached a fan to the northbridge. That little chip sure does get hot but mine hasn't blown up yet so I'm ignoring it. 😀
Reply 18 of 60, by SquallStrife
The 865PE chipset on my old 478 Gigabyte board had a fan on it from the factory. They are toasty little buggers.
Reply 19 of 60, by jmrydholm
Very nice system!
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
