After speaking with this particular seller on the phone, he claims that eBay automatically puts a time limit on when a user can re-bid when a previous auction has been "cancelled." He said to try again in a few days, but I am still banned. He also doesn't reply to my inquiries, particularly my request for his return address in Chinese characters.
I'm now 22 CPUs into this benchmark comparison, which is about 1 CPU/day. I've added a few more socket 3 processors, just for comparison, for example, an Intel DX4-133 (2x66), AMD X5-133/160, POD83/100, and IBM 5x86-100/120/133. High FSBs used whenever possible. I've updated the test matrix, but I have a couple of questions from you guys about the benchmarks.
Do you know the dominant test types for the benchmarks listed below? I have encluded my best guesses, in order of most dominant. Options are ALU, FPU, GPU, RAM throughput (including L2 cache), and PCI BUS. Some of them are obvious, but for others I may need to look at the documentation. My guesses are based loosely on the data tabulated so far. I'd include any of the above noted features if they contribute to 25% or more of the total score.
Symantec Sysinfo v8.0
ALU
PiDOS
FPU
Landmark v2.0
ALU - Integer
FPU - Floating-point
PCI BUS - Video
Bytemark v2, 32-bit DOS
ALU - Numeric Sort
ALU - String Sort
ALU - Bitfield
ALU - FP Emulation
FPU - Fourier
ALU - Assignment
ALU - IDEA
ALU - Huffman
FPU - Neural Net
FPU - LU Decomposition
ALU - Integer Index (% of Pentium 90)
FPU - Floating-point Index (% of P90)
Roy Longbottom Dhrystone v1.1
DHRY1OD (VAX MIPS Rating)
ALU
Roy Longbottom Whetstone
FPU - WHETCOD, MWIPS
FPU - N1, Floating Point (MFLOPS)
FPU - N2, Floating Point (MFLOPS)
ALU, FPU - N3, If Then Else (MOPS)
FPU - N4, Fixed Point (MOPS)
FPU - N5, Sine, Cosine (MOPS)
FPU - N6, Floating Point (MFLOPS)
FPU - N7, Assignments (MOPS)
FPU - N8, Exp, Sqrt, etc (MOPS)
Speedsys v4.78
ALU - Total Score
PCI BUS - Video Memory Bandwidth
RAM - System Memory Bandwidth
ALU - L1 Cache
RAM - L2 Cache
RAM - Memory Throughput
Cachechk v7.0
ALU - L1 Cache
RAM - L2 Cache
RAM - Memory
3Dbench v1.0c
ALU, GPU
Doom v1.9s timedemo1
ALU, GPU
Pcpbench v1.04
ALU, GPU
Quake v1.06 timedemo1
FPU, GPU
SuperPi v1.1
FPU
Ziff-Davis Winbench96
ALU, RAM - CPUMark32 v1.0
ALU, GPU - Graphics WinMark v1.0
Ziff-Davis Winbench99
ALU, RAM - CPUMark99 V1.0
FPU - FPU WinMark99 v1.1
Ziff-Davis 3D Winbench97 v1.0
FPU, GPU, RAM
WinTune98
ALU - Integer (MIPS)
FPU - Floating Point (MFLOPS)
GPU, MMX - Video 2D (Mpixels/s)
GPU, MMX - Direct3D (Mpixels/s)
GPU, MMX - OpenGL (Mpixels/s)
RAM - Memory
Sandra99
ALU - Dhrystone (MIPS)
FPU - Whetstone (MFLOPS)
ALU, MMX - MMX/3DNow: ALU Integer (it/s)
ALU, MMX - MMX/3DNow: FPU Floating Point (it/s)
RAM - Memory: ALU Bandwidth (MB/s)
RAM - Memory: FPU Bandwidth (MB/s)
PassMark v4.0
GPU - 2D Graphics Mark
RAM - Memory Mark
ALU, FPU - Math Mark
ALU, FPU - Math Max MFLOPS
MMX ALU, FPU - MMX Mark
ALU - Integer Addition
ALU - Integer Subtraction
ALU - Integer Multiplication
ALU - Integer Division
FPU - Floating-point Addition
FPU - Floating-point Subtraction
FPU - Floating-point Multiplication
FPU - Floating-point Division
3DMark99Max
MMX FPU, GPU - Graphics 3DMarks
MMX FPU - CPU 3DMarks
Final Reality v1.01
GPU, FPU - Direct3D - Overall Marks
FPU - Software - Overall Marks
GPU, FPU - Direct3D - 2D
GPU, FPU - Direct3D - 3D
GPU, FPU - Direct3D - Bus
FPU - Software - 3D
MDK Performance - Direct3D
GPU, FPU
MDK Performance - Software
FPU
Quake2 Timedemo1 - OpenGL
GPU, FPU
Quake2 Timedemo1 - Software
FPU
