d1stortion wrote:That Vaio setup looks amazing! Any more information on it?
Eh, there's not much to tell. The 1000 RSX is pretty generic feeling, as far as Tandy systems go, and is more appropriately a member of the 2500-series besides (one of which uses the same motherboard), given that it only includes a single carry-over from the 1000-series - the PSSJ-3 chip. Unfortunately, due to its AT-class architecture, the sound ports were all changed so as to not conflict with the addressing of the second DMA channel, breaking the "Tandy" sound support for any software not designed to query for, or reference, the changed ports.
It's still an okay 386 system though. In the pictured configuration, I'd upgraded the 25MHz CPU with a REV-to-486 upgrade, maxed-out the RAM to 9MB, swapped the 52MB hard-drive with a 340MB IBM MicroDrive, and installed a GUS PnP and Media Vision Memphis (PAS-16 compatible) interface in the two ISA slots. The Memphis CD-ROM unit is pictured on top of the system, and its corresponding Bose speakers flank the monitor. (They're not at all related to the VAIO monitor itself, but just happen to be of matching color.)
It's got just enough horsepower to run Microsoft Bob on Windows 3.1. 😀
I'm constantly vacillating between keeping the RSX, and letting it go. I simply don't use it with any sort of consistency. At present, it's sitting on a shelf with the complementary pairing of a Yamaha SW20-PC and SW60XG installed in the ISA slots, doing absolutely nothing.
sliderider wrote:Is that floppy drive with the blue eject button from an IBM PS/1?
The look is pretty similar, but no, it's stock. I suppose Tandy felt like they were being clever by using buttons with rounded corners. 😀
