I bought the case as a used product,not so much becouse of the looks,but becouse it's spacious and has the psu mounted horizontaly,back in 2000-2001 i had an atx case which had the psu mounted vertically parallel with the motherboard,covering the cpu area and making acces to the cpu hard,plus u had to be carefull about how tall the cpu cooler and fan was,so it would fit.
Curiosity: does that Pentium 2 actually need the cooling fan if you aren't overclocking it?
Haven't tried running it without the fan,i need to install some monitoring program to work on windows 98se,so i can monitor temperatures from windows.
Will an older version of motherboard monitor work?
