First post, by Skyscraper
When I joined Vogons I had just bought a small Super Socket 7 Box with a mATX motherboard.
I bought this box because I wanted a Super Socket 7 DOS/Windows 98 gaming rig.
When things diddnt go as planned I started tinkering with a Compaq Deskpro motherboard and later the Leviathan build.
The thing that stopped the original plan for this box was a motherboard full of bad caps.
The solder points on this board is really really small so I diddnt feel like even trying to fix it.
Then I thought of using the case for something else but there were some problems.
The case uses a special small 112w PSU with weak rails. 3.3V 6A, 5V 10A and 12V 3A wont run many systems.
With not enough room for a larger PSU I had to make do with the (lack of) power the small PSU offered.
In some other thread I was told that playing Unreal using 800*600 resolution was like having sex with a cactus, possible but not desirable.
With my Voodoo 2 or the Banshee I use for my Socket 7 builds higher resolution is not possible or to slow so I thought that I might aswell build a fast voodoo 3 box for this purpose.
A fast voodoo 3 box that can run with the small PSU described above... quite the challenge!
Since the case is Micro ATX I needed a suitable Pentium 3 or Athlon board.
Since I dont think an Athlon of any kind would fit in the power envelope a Pentium 3 board seemed like the only choice.
The Pentium 3 CPU that needs the least amount of power is a Tualatin and the Tualatin that needs the least amount of power is a slow Celeron.
I found a QDI Legend Advance 6T board with a Tualatin Celeron 1100 on Tradera (Swedish Ebay). The price was ~10$ which seemed fair.
System spec
Motherboard: Qdi Legend Advance 6T
CPU: Tualatin Celeron 1100
Memory: 2x 512mb PC133 CAS2 SDRAM
GPU: PCI Voodoo 3 2000
Sound: The integrated sound on the motherboard.
HDD: Samsung 80gb
OS: Windows 2000
The end result is great
It plays Unreal (gold) at 1024*768 with high fps and that is really all I asked for.
Peak power is 100w at the socket but I think the PSU has really bad efficiency.
Some Pictures
The case
The old Socket 7 board with bad caps
The new motherboard
Lots of amps...
My PSU is larger than... my other PSU
The new motherboard fits in the case!
Everything in place
Enough memory box ticked
Intresting sound options in the BIOS setup.
Peak power
Reply 1 of 11, by nforce4max
Role over all fall to the floor laughing 🤣
Reply 2 of 11, by TELVM
Skyscraper wrote:
http://s21.postimg.org/jr2xu4it3/KILLAWATT.png […]
That's raw AC power draw from the wall. For the real DC power draw we must multiply that number by the PSU efficiency, which for such a venerable PSU should be 75% at best, so 100 x 0.75 = 75W real DC draw or less.
So as weird as it sounds that 112W PSU is overkill for a PIII system 😀 .
Let the air flow!
Reply 4 of 11, by JaNoZ
I know these hipro psu,s.
You might want to open the psu to check for bulged filter capacitors near the atx power cords, they can also be leaky.
If so replace them if you want your new hardware to keep in this world. 😀
Btw after reading your first post again this bad filtered lines from the psu might be the cause for the socket7 board to get problematic in the first place, really check out the psu or the new board can bsod you in some days onwards.
I would replace the caps on the socket7 board though
Reply 5 of 11, by Skyscraper
JaNoZ wrote:
I know these hipro psu,s. You might want to open the psu to check for bulged filter capacitors near the atx power cords, they ca […]
I guess I will have to open up that little sucker to see if there are some bad caps. Thanks for the heads-up.
I would recap the socket 7 board if the soldier pads were the normal size. They are so small that I dont think I would succeed.
Reply 7 of 11, by Skyscraper
I think I would manage with those expansion slots.
The board I replaced it with has exactly the same layout.
1x Voodoo Banshee or Voodoo 3 PCI
1x Soudblaster AWE64
1x PCI for other uses
With the P3 board the ISA slot wont be used but I might put a Soundblaster Audigy in one of the free PCI slots.
Reply 8 of 11, by Skyscraper
It is time for a follow up.
I have upgraded this box to a Celeron 1300, downgraded the HDD and installed Windows 98.
I did some benching with the new CPU and the Voodoo 3 2000.
New spec: Celeron 1300, Via Apollo Pro 133T, 512 mb SDRAM@133MHz CL2. Voodoo 3 2000, Some random ~17GB IDE drive, Windows 98SE.
First off is Super Pi. This is actually really bad, it gets beaten by a huge margin by the Coppermine Celeron 1100 on Intel 440 BX.
But wait I have not installed the chipset drivers, that must be the problem! ... No.
Sisoft Sandra 99. The memory scores are just awful.
The CPU Mark 99 score is better.
3dmark 99 seems to score OK
3dmark 2000. Ok..ish
With the Voodoo 2 2000 overclocked from 143 MHz to 190 MHz the scores improve.
3dmark 99
3dmark 2000
I did also run some game benchmarks. (16bit)
GL-Quake
Celeron 1300, Voodoo 3 2000 640*480: 163.9 FPS
Celeron 1300, Voodoo 3 2000 1024*768: 59.9 FPS
Celeron 1300, Voodoo 3 2000 OC 640*480: 210.4 FPS
Celeron 1300, Voodoo 3 2000 OC 1024*768: 78.9 FPS
Quake 3
Celeron 1300, Voodoo 3 2000 640*480: 84.1 FPS
Celeron 1300, Voodoo 3 2000 1024*768: 38.8 FPS
Celeron 1300, Voodoo 3 2000 OC 640*480: 93.2 FPS
Celeron 1300, Voodoo 3 2000 OC 1024*768: 51.9 FPS
Unreal Gold
Celeron 1300, Voodoo 3 2000 640*480: 103.5 FPS
Celeron 1300, Voodoo 3 2000 1024*768: 50.3 FPS
Celeron 1300, Voodoo 3 2000 1280*1024: 37.6 FPS
Celeron 1300, Voodoo 3 2000 OC 640*480: 113.4 FPS
Celeron 1300, Voodoo 3 2000 OC 1024*768: 75.1 FPS
Celeron 1300, Voodoo 3 2000 OC 1280*1024: 45.1 FPS
In Unreal at 640*480 with the Voodoo 3 overclocked, the system is a bit bottlenecked by the CPU.
The overclocked Voodoo 3 scales much better than it should in Unreal at 1024*768. I do not know why but I have read that others also have experienced this.
Reply 9 of 11, by nekurahoka
Possibly because of Unreal's optimized glide implementation? Everything I've read about the game's development says glide was the major focus. I bet a comparison of it running other graphics APIs at those resolutions would shed some light.
Good build. I like the micro case too. I'd paint it, but I love the size and shape.
Dell Dimension XPS R400, 512MB SDRAM, Voodoo3 2000 AGP, Turtle Beach Montego, ESS Audiodrive 1869f ISA, Dreamblaster Synth S1
Dell GH192, P4 3.4 (Northwood), 4GB Dual Channel DDR, ATI Radeon x1650PRO 512MB, Audigy 2ZS, Alacritech 2000 Network Accelerator
Reply 10 of 11, by PhilsComputerLab
This might help:
Full size: http://i.imgur.com/pJQksYS.png
More 3dfx Voodoo shootout benchmarks: http://www.philscomputerlab.com/3dfx-voodoo-s … ut-project.html
YouTube, Facebook, Website
Reply 11 of 11, by Skyscraper
The non overclocked results are right on the mark. 😀
I only wished it had a little more powerful PSU.
I did the overclocked benching with another PSU that wont fit in the case just to be on the safe side.
