Reply 21 of 142, by jwt27
My favourite for DOS gaming would be Pentium 2/3 Deschutes/Katmai (pretty much the same thing). Rock solid platform, and runs about every 90's DOS game perfectly.
Reply 22 of 142, by Tr3vor42532
My favorite is probably the Pentium MMX 200-233MHz. They seem to be a very good sweet spot for early windows gaming and runs pretty much all dos games except for the few that are speed dependent.
My YouTube channel: https://www.youtube.com/user/Tr3vor42532
Reply 23 of 142, by sliderider
bristlehog wrote:
Pentium II Overdrive PODP66X333, the fastest CPU to use with system native to ISA. Some say that there are ways to install a Tualatin into a Socket 8, but I haven't found any yet.
There was this, actually.
http://hexus.net/tech/reviews/cpu/125-powerleap-pl-proii/
MUCH faster than a PII Overdrive.
Reply 25 of 142, by sliderider
bristlehog wrote:
Is this intended for Coppermines?
I've only ever seen them sold with 700mhz Celerons installed, so I'm guessing they were designed for Coppermines. I think you would probably be pushing your luck if you tried to use a Lin-Lin adapter on top of one of these to get a Tualatin to work.
Reply 26 of 142, by tincup
I'll second the Celeron 300a. It arrived at a very affordable price, and an easy over-clock @ 450 beat down anything I could hope to acquire at that point. In a time when upgrades seemed to be necessary every few months the C300a held it's own for quite a bit.
Reply 27 of 142, by vetz
Pentium Pro.
A huge leap forward when it came out in 1995. Paved way for the PII, PIII, Tualatins, Pentium M and Core architecture.
Reply 31 of 142, by gerwin
If I would have to choose: Deschutes core Pentium II 400 (Pre week 31 1998). Because;
-Multiplier unlocked.
-I like slot 1, for easy CPU swapping and tinkering.
-Half speed L2 cache is fine for gaming.
-Does 66/100/133 FSB and MTRR LFB Write combining, which is a must for hi-res framerates.
-Does not run hot. Has heat spreader with cache cooling pads.
Reply 32 of 142, by GeorgeMan
1st place: PIII 750 Coppermine slot1 100MHz FSB.
Because: Suites in my slot1 AT mobo and I can play any game from early DOS to early 2000's (except those with speed issues). All the hardware fits in an AT case, must have for nostalgia.
2nd place: 486DX2/66.- No comments xD
Core i7-13700 | 32G DDR4 | Biostar B760M | Nvidia RTX 3060 | 32" AOC 75Hz IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 34 of 142, by sunaiac
Very hard to answer ...
I'd put the DX4 100 Intel Write Back on the first spot.
Then probably The Athlon Classic Slot A, any of the 500-700MHz range.
And I'd close the podium with the FX Athlon line, socket 940 and 939.
runner ups : 1MB ppro, the Pentium 2 line, the P3S.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 36 of 142, by borgie83
Intel DX4-100. Always had a soft spot for these as it was in my first computer.
I'd have to say though that the Pentium 3 1.4Ghz Tualatin is a beast and the perfect retro cpu in my opinion. Fast enough for all dos games and later windows games as well.
Reply 37 of 142, by retrofool
Pentium Pro here as well. I used a PPro 200 machine O/C'ed to 233 with a PCI Voodoo 3 2000 in 1999 because of, uh, cash flow problems and I played Janes WW2 fighters on it constantly. I was quite amazed at how capable it was even then.
can't seem to throw anything out...
Reply 39 of 142, by badmojo
486SX33 - relatively cheap in '93 when I got it thanks to Intel's marketing tactics at the time. Nothing I was interested in needed a maths co-pro anyway - going with the SX saved a couple of hundred bucks and it was quick enough for DOOM, which was all that mattered.
