Robin4 wrote:Do you also have picture made from the front of this case? I think some people mayby want to know which case you are using now. […]
Iam also thinking of buying better psu`s for my retro systems. The quality of the psu`s back then which came included with the case was mostly the worst psu you can get. They where only nice to drive the system for some time and where cheaper with building to whole system. But if you have plans to run this system for a while, i can recommend to buy a real a-brand psu..
1. Then you know you are on the save side ( a-brands don`t blow apart easilly) And the voltage lines are more stable.
2. Low quality psu`s consume more power from the wall socket. ( because they dont work much efficient)so i the long terms, you really can save a lot money on power (electric bills)
I use a mix of older PSU and some not so old ones, but they all have one thing in common: They were pretty solidly build.
When I started my computer hobby, I kept all the heavier PSU's (that's "usually" an indication they were well build). Most of my older PSU's were made by FSP (Fortron). This is why I have ample PSU's for Socket A builds, I got them here and there. I did have to throw a couple of them out because they had one or several leaking caps though, but so far the ones I had from the start and didn't have any bad caps, still don't have bad caps now.
Of course these PSU's are older now and not as efficient, but they should still do the job well enough.
But to be on the safe side, I always open up one of the older PSU's I intend to use in one of my builds and check for bulging/leaking caps before I actually use them to set power to one of my boards.
Of course just buying new ones is more safe and probably also cheaper in power (because they are more efficient), but for retro builds I don't use that much anyway, all I care about is stability. And besides, I can't afford to buy brand new PSU's for all of my builds anyway.
