First post, by soviet conscript
- Oldbie
One thing Ive noticed is that when someone builds a high end hot rod 486 its usually based on a PCI board which are not so common. lately I acquired this board http://motherboards.mbarron.net/models/486vlb3/m912v17.htm which though not a PCI board captured my attention for several reasons
1) 72 pin RAM
2) Lithium battery
3) 1mb l2 cache which i don't see often on 486 boards.
this system will be running DOS and Win 3.1 only but I really wanted to push its limits so to that end I have questions.
RAM, am I better off with 2 x 32 or 1 x 64 MB sticks? I asked because there was some disagreement on which gives slightly better speed results in a thread I was reading awhile back
L2 cache, will I see any benefit of full 1mb cache as opposed to say 512kb if the board only supports up to 64MB of RAM?
CPU, I have a AMD 133 running on my infamous m919 board and I wanted to play around a little with a Cyrix chip so I have some questions to that effect. I read that despite the mhz difference the Cyrix 5x86 100 is still about as fast as a AMD 5x86 133mhz. any truth to this? also would this board be able to overclock a AMD 133 to 150mhz or a Cyrix 100 to 120mhz and if so which is faster? would it mess with the VLB bus?
finally the 2 VLB video cards I have available ATM are a diamond speedster with 1mb based on the cirrus logic ship and an S3 card with a 805 chip and at least 1mb or ram maybe 2.
