First post, by eFatal2ty
So after a couple of builds, now its time for Tualatin.
My show is something similiar to this:
-ASUS TUSL2-C (i815EP) or ABIT VH6T (ApolloPro133T) board
-Intel PentiumIII-S 1.4GHz (found)
-768-1.5GB SDRAM CL2
-nVidia GeForce4 Ti AGP4x for full DX8.1 support (ASUS 4600Ti 128M found)
-SoundBlaster Live! 5.1 MP3+ or Audigy1 (both found)
-IntelPRO100 LAN
-2x60/80GB ATA133 RAID0
-350W ATX
-MS Windows 2000Pro SP4
i dont have anything from this, I start searching for parts and post here my achievements
*ASUS P3B-F *Intel Pentium!!! 450MHz Katmai@133fsb *Hynix 4x128MB SDR PC133 CL2 *Matrox G400MAX 32MB + Procomp Voodoo2 12MB SLi *Creative SB Live! CT4760 *3Com 3C905C-TX-M *2xSeagate 40GB 7200rpmn *EIZO T68 19"CRT * Creative FPS1000 *OS: MS Win 98SE
Reply 2 of 7, by maximus
Awesome, sounds a lot like my Ultimate Windows 98 Machine! (described here and here)
A few things to be aware of:
- As mentioned by Kamerat, the TUSL2-C is limited to 512MB of RAM. That will be plenty for period games, though.
- Be careful with Sound Blaster Live! 5.1 model numbers. The driver package on Creative's site only supports the SB0060, so this is the one to get for foolproof compatibility.
- The Pentium III 1400S will bottleneck the GeForce4 Ti4600 big time. The Ti4200 might be a better pick for this build.
- If you go with the TUSL2-C, you'll need to install Intel Application Accelerator to get UDMA working. This board also had shutdown issues with the Sound Blaster Live! 5.1 - I fixed these by disabling the parallel port and one of the serial ports (wasn't using them anyway).
Have fun, and good luck! 😎
PCGames9505
Reply 3 of 7, by obobskivich
For '01-'02 I'd probably go Pentium 4 or AthlonXP - specifically due to the bottleneck issues that Maximus points out. One advantage if you go AthlonXP is that most of the coolers will be inter-changable with S370 as well (they use very similar mounting). Some other things to think about:
- Radeon 8500 offers tessellation features that some games from this era support, if you're interested in playing around with that.
- Audigy and Audigy 2 are period correct for this era as well, and afaik have more uniform driver support.
Reply 4 of 7, by eFatal2ty
AthlonXP machine will be too https://www.youtube.com/watch?v=OzulsKZMfPE but a little diferent, than in video - case, PSU, VGA -rest the same
Reply 5 of 7, by eFatal2ty
So!
finaly i have this:
Abit ST6 i815EP
IP3-S 1.4GHz + Spire Whisperock
2x256MB PC133 CL2
Creative GeForce4 Ti 4600 128M
Creative SB Audigy2
Intel PRO/100
Adaptec 1200A
Missing parts:
Case
PSU 350/300W
2x80GB ATA100 RAID0
ZIP100 and another CDRW/DVD
I turned it on, and it POST 😀
11124604_10204659507551196_6165347796652030669_o.jpg 11402438_10204659507431193_130679555507666295_o.jpg 11713911_10204659507711200_7912357024038817030_o.jpg
Reply 6 of 7, by blank001
For 2002 in XP, I would go Athlon XP, for 2002 in 98SE a 1400S works well.
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 7 of 7, by eFatal2ty
Temporary Case and Fortron 400W PSU and 2xMaxtor DiamondMAX9 80GB 7200rpm at home, now running W2K
Where is your AthlonXP or P4 now? 😁 I will go Higher, CPU, chipset and RAM is sooo cold!
