HP NetServer 4d/66LE
Reply 20 of 26, by i386
I have old 486 server(Opti chipset). It works with single memory module, but needs ECC/Parity
module. IIRC with regular modules, it only beeped.
Please post the big photo of memories that you have used. We would discover, it is ECC/Parity or not.
Reply 21 of 26, by PCBONEZ
A good place to find photos like that is ebay - even if you aren't going to buy there.
Does your computer take 30 or 72 pin RAM?
Reply 22 of 26, by bristlehog
There are four 72-pin slots.
Markings on memory I used are hard to see, especially on a photo. I'll describe them myself:
8-chip double sided
Each chip has markings:
TI -60
TMS417800DZ
VC 66A9E9 P (this marking is unique to each chip)
Hardware comparisons and game system requirements: https://technical.city
Reply 23 of 26, by i386
It is non-ECC FPM memory module.
But strange, every chip is 2M*8bit, hence at the every side 8*8 =64bits!
Regular modules used x4 chips. Probably some data pins just doesn't use in this module?
Or you have 8 chips total, 4 chips a the one side and 4 chips at the another side?
Anyhow, try to find ECC/Parity FPM modules(these modules have more than 8 chips(at the every
side) and ECC/Parity chips usually different than main chips.
Reply 24 of 26, by bristlehog
Right, 8 chips total, 4 each side.
Reply 26 of 26, by Stojke
I had no idea this case type had an protective plastic plate! Vectra 5 XU is my favorite computer of all time. Sleek design, dual CPU, sadly the plastic quality is not that great. The little clips on the back dry out and snap after a lot of openings. Mine is in good shape besides the little plastic clips (That some one broke way before me anyway, on one side).
Sadly, I managed to find replacement motherboards for it but never any replacement cases 🙁
