Thank you tetrium! It does look good indeed 😎
And yes, I'm aware of that. I touched the regulator and it's ok. Without fan the heatsink goes a little hot. Not as the original heatsink, but I think it will be neccesary to keep some 40 mm fan as it keeps it really cold.
Now I'm doing some tests at 200 mhz with the damaged fan and it's all ok. Still waiting to find some terminal connectors to restore the front panel.
Other topic: I just found that my motherboard doesn't have turbo switch connector. But I do remember the switch beeing conected to led display AND to the motherboard with 3 pin connector in both. I just can't remember where it was connected, and the manual doesn't say anything about it. I just read this:
TB_LED: Indicates if the system speed is in normal or turbo...
So I can assume it does have some turbo function. But the only "misterious" pins are two between speakers connected to nothing (I've checked tracing the motherboard). Then two pins labelled "OUTLET" (unknown function) and five pins labelled "MS_JMP" but I think they are for mouse or something.
I'm a little confused here... I can always play with fsb, multipliers and switchs, but I do remember turbo button working on this computer. For the record, it wasn't connected to fsb and/or multiplier. Those are two pins rows and the turbo connector has three pins.
