candle_86 wrote:MVP3c2 is good, my PSU was dying and didn't even know it, swapped it out and its running just dandy now. […]
Now loading 98SE drivers onto it.
Also what is the card type I'm looking for that has PS/2 ports that are useable without drivers?
I would like PS/2 instead of USB and finding a Serial Opticial mouse is nearly impossible.
On another note my AWE32 busted a capactior and now I guess I have to buy an iron to fix it, as well as my USB 2.0 card, and I guess I might as well fix my 7600GS.
Your board already has PS/2, you'll need a few cables to be able to use them though.
See link
For reference:
Standard Baby AT form factor.
UltraDMA-33 EIDE Controllers. (Up to 4 IDE devices).
Backwards compatible with PIO mode 3/4.
UltraDMA-66 supported on EP-MVP3C2 only.
* 66/75/83/95/100MHz Host Bus.
3x DIMM Slots for SDRAM.
384MB max. supported.
PS/2 connectors.
1 PS/2 mouse.
4 (32-bit) PCI, 2 ISA & 1 AGP.
AGP supports 1x and 2x modes.
Onboard cache.
512KB.
If it's an AT Pentium board, one can always assume it actually has PS/2, but anything clonewise prior to ATX will most likely need a cable for it (kinda like modern USB front bezel is attached to modern motherboards, only these would usually go to the back of the case instead of the front).
The cables themselves look like this one (often they have multiple connectors attached to a single L-shaped metal thingy that also takes a slot in the back of the AT case, just like AGP/PCI/ISA cards do)
