Reply 40 of 49, by feipoa
Are the two mice on the same desk and using the same monitor as your everyday online activity computer? Mine were and I found it really irritating switching back and forth between modern and retro box, then having to grab another mouse. If the multiple monitors are on a desk with only retro computers, then I probably wouldn't find it as irritating.
Reply 41 of 49, by Hellistor
I have seperate desks for old and new. On the left side of the room I have the Retro Desk with two sets of monitor keyboard and mice then I have a small cabinet between the desks and on the right is my Current Desk with my guitar amplifier standing on top of the desks where they meet.
I would take a picture of it all but my current desk is, well, let's say "unorganized" right now. 🤣
Dual 1GHz Pentium III machine
700MHz Pentium III machine
550MHz PIII IBM 300PL
Socket 7 machine, CPU yet undecided
100MHz AMD 486DX4 machine
Reply 42 of 49, by yawetaG
clueless1 wrote:
This will only work on PS/2 mice that are serial-compatible. That rules out most, if not all modern PS/2 mice. I went through […]
yawetaG wrote:
Hellistor wrote:
Well you don't really need a "AT compatible" KVM. A normal PS/2 KVM would work well enough for most stuff. You can just get an adapter for the keyboard. The only problem would be serial mice but you can just have several mice next to each other, they're easier to keep around than keyboards.
PS/2 mouses that can be used as serial mouses with a PS/2->serial adapter exist. Wouldn't those work?
This will only work on PS/2 mice that are serial-compatible. That rules out most, if not all modern PS/2 mice. I went through quite a few mice before I found one that worked. It's a Logitec MouseMan, Serial-MousePort. This one:
http://gordogato.com/oscommerce/catalog/produ … products_id=176
I'm sure there are others. But these are likely first generation PS/2 mice when they co-existed with serial in the market, so they had to make them electrically compatible (they usually came with adapters in the retail packaging).
That's why I wrote "that can be used as serial mouses". I'm pretty sure early Microsoft mouses (the glossy white that yellows strongly over time ones) also came with those adapters.
Reply 43 of 49, by clueless1
Sorry dude, I wasn't trying to correct you, I was just elaborating with more detail.
Reply 44 of 49, by Hellistor
UPDATE!
I have now aquired a Roland Sound Canvas SC-33 as well as a Quickshot Squadron Commander QS-202! High Resolution pictures can be found here
This is how I have the two Roland modules set up:
The Midi goes into the MT-32 and a cable takes the Midi from it's Midi thru to the SC-33.
The cable on the left of the unit goes to the line-in on the Terratex Meastro 32/96 soundcard.
Thanks to the cable coupler I can switch the output cables from the MT-32 and the SC-33 within a few seconds to use the device best suited for each game.
I really like the sound from the SC-33 but hey, that's to be expected!
This is what the whole setup looks like:
You might notice that I have switched the speakers. The other ones have a problem with the left speaker. I have to see if I can repair them.
These used to have a problem as well but I soldered a new cable and they work perfectly now. I'm probably going to keep these since they sound better.
One thing I'm not sure about anymore in this build is the soundcard.
The Terratec Maestro 32/96 is a fantastic "jack of all trades", since it has a good OPL3 clone and high-quality onboard Midi.
However, since I now have the SC-33 the biggest selling point for me, the onboard Midi, is moot.
There are also a few slight problems with the card. The DOS mixer doesn't always keep the settings and the DOS driver is quite big compared to say a Soundblaster 16.
I'm likely going to change out the card for the CT 1740 SB16 with DSP 4.05 (hanging note free) from my "Strix" Pentium build. I'm probably going to put a CT2230 (type 2 hanging note bug only) in that instead.
Here are some short camera recordings of the SC-33 in action:
Doom E1M1
Tyrian 2000 Jukebox
Now, the Quickshot Squadron Commander is functioning and in great physical condition. However, it didn't come with any drivers or the manual. I found the correct driver online but I can't find the manual.
Thus I have been unable to correctly use the device. If anybody has the manual, I'd greatly appreciate it if you could send me a pdf or even some crappy phone pics as long as I can read it.
Well, that's all for now, I hope you enjoyed it!
Reply 45 of 49, by cj_reha
Requesting a picture of the jumper settings for that display. I've got the same CPU in a very similar case which I gave up on and left it at 100 for both turbo on and turbo off. A pic would be super helpful.
Reply 46 of 49, by Hellistor
Sure, no problem.
Here you go:
If you need the picture in a higher resolution here you go.
Just so you know, this probably only works with the same model display (TD-38S) and if you have a different one I sadly can't help you. Good Luck though!
Reply 47 of 49, by Tetrium
Another build using the VI15G, this board seems to be pretty popular!
Does your VI15G also have gold-plated SIMM sockets?
My retro rigs (old topic)
Report spammers here!
Reply 48 of 49, by Hellistor
It seems to be! But for me it was more of a coincidence. A friend of mine (Max_tor) bought a Cyrix CPU off somebody. During the transaction the seller mentioned that he also had a 486 machine somewhere, but he wasn't interested since he's not much of a DOS guy. He then told me about it and I snagged it and some other goodies.
The machine had the motherboard in it. I only later realized that it was the same motherboard that LGR/Clint used for his Woodgrain 486 which was the reason I wanted one in the first place. I was slightly amused at the coincidence.
I really like the motherboard. Especially because it has the same BIOS type as my Dual PIII with the GUI and mouse support.
I just checked, yes it has. Neat!
Reply 49 of 49, by spacedrone808
Hellistor wrote on 2016-11-21, 21:08:
Maaaaan! Case!!!!! What's the brand??
It is super mega cooool!!
Obsolete Projects: https://win7sp2.neocities.org
