First post, by tomoa
Abit BX133-raid Pentium III-S 1400 MHz
Motherboard works on 133 MHz, vcore 1.45v, PCI/FSB 1/4, AGP/FSB 2/3, modded processor Tualatin to work with Intel BX and other older chipset for Coppermine processors, modded motherboard BIOS - new bios for HPT370/372 controller now 48 bit lba, works now with hard disk greater than 128 GB. Processor temperature is about 40 degrees Celsius.
System is very stable, no problems.
case: Cooler Master elite 331 (2 x case coolers 120 mm 1200 rpm - front and back)
power supply: Chieftec GPS-350EB-101A 350W
motherboard: Abit BX133-raid
processor: Pentium III-S 1400 MHz / 512 kb / 133 MHz SL5XL (modded)
processor cooler: Spire - WhisperRock IV (SPA04S4-2)
memory: 2 x 256 MB SDRAM PC133 CL3
video card: Leadtek WinFast A350XT (Geforce FX 5900 XT) 128 MB
hard disk: 80 GB Hitachi, 120 GB WD, 300 GB WD (all 7200 rpm)
CD-ROM: Teac 52x
sound card: Sound Blaster AWE 64 Value ISA
NIC: Realtek 8139D
fdd: Teac
monitor: Eizo FS2333-BK
keyboard: A4 Tech X-Game G800 ps/2 (gaming keyboard)
mouse: Logitech optical mouse ps/2 SBF-96
OS: Windows XP SP3, Windows 98 SE SP2.1b, MS-DOS 6.22
Benchmark: 3D Mark 2001 SE default settings - 9558 score
    356.54 KiB
    2.03 MiB
    2.66 MiB
    2.34 MiB
    2.88 MiB
Poland , http://komputery-retro.ddns.net/ http://komputery-retro.ddns.net/blog/ , I like old games and old computers 😀
Reply 1 of 8, by chinny22
Perfect late dos gaming PC if you ask me!
Personally I'd add a better PCI Soundcard for windows gaming though. SB Live though to Audigy 2 ZS will all work in Win98 & XP
Reply 2 of 8, by tomoa
I have SB Live! SB0100, but I prefer ISA card for better compatibility in DOS games.
I made the computer to have 100% compatibility in windows XP, Windows 98 SE ans MS-DOS. Before I made computer on chipset intel 865G
My PC for Windows XP + Windows 98 SE + DOS
with Geforce FX 5900/6800, Pentium E5800 3.2 GHz, 2 GB RAM, SB Live!, a had a lot of problems in Windows 98 SE (even with himemx with memory limit to 512 MB RAM) and DOS, only Windows XP was working fine.
Reply 3 of 8, by chinny22
I meant install both cards, use AWE in Dos and set the Live as your primary sound device in Windows. That way you benefit from a card with a cleaner output and EAX, etc.
Of course its your system and if your happy then ignore me!
Yeh I've got a similar "modern" Win98 build only based on Socket 478 and a 6800. I've got win98 installed but it was a fight, I ended up getting the Rlowe ram patch, and in the end I still use my P3 anyway! Just feels more correct?
Reply 5 of 8, by Jade Falcon
Rank BANNED
BANNED
Am I the only one wandering why your hard drives and cd drive are not hooked up?
Also if your ram can take it Id ether run them at cl2 or set the FSB to 142mhz.
Nice system by the way
Reply 6 of 8, by kixs
If you take a look at the POST screen photo, you'll see that everything is connected. I guess he removed the cables for better view of the motherboard.
PS:
I wish I had more s370 to Tualatin adapters... khm.. I only have one 🙁
Reply 7 of 8, by tomoa
I put another memory RAM modules and overclocked sytem from 133 fsb to 150 fsb on Intel BX.
Ssytem is not very stable but it works.
    318.13 KiB
Reply 8 of 8, by tomoa
3D Mark 2001 SE default settings with 2x SDRAM PC142 Apacer on PC133 CL2
9916 score
3D Mark 03 default settings with 2x SDRAM PC142 Apacer on PC133 CL2
4385 score
    324.28 KiB
    336.19 KiB
