Reply 20 of 27, by pojo
I managed to dump the BIOS with NSSI:
Thanks!!! I really appreciate this favour.
@tabm0de
Did you ever get any ISA cards working? My machine does not seem to detect any cards at all. Maybe some jumper setting is needed?
wrote:@tabm0de
I did only test sound card on the one I sold, did mean display card only or any card at all?
naa, nothing yet...
I tried both a SB16 and a 3Com network card. NSSI reports no cards, and if I run SB16 DIAGNOSE.EXE or Adlib Jukebox they just report that there is no sound card in the system.. 🙁
Little update- I tested an 8-bit CGA card, that worked. I also tested a 16-bit ATI Mach64, that did not work, I got a continuous PC speaker beep. Internal VGA was disabled in both cases.
@pojo
You have a email 😀
I found that DIAGNOSE.EXE cant be truseted, i had the same problem with a diffrent sound card on my compaq presario aio ( Cant install Compaq Business Wavetable ( ess1869f )in win3x ).
If i skip diagnose and just install ctcm and it finds the pnp card at boot ( CT2940 )
naa, nothing yet...
Didn't have any luck with Sound Blasters. CTCM.EXE detects it but after that, the keyboard just triggers random characters on the screen (?!) 😕
I have an ESS card on the way, will test that instead.
