Via C3 Ezra Slot 1 Machine
Reply 60 of 76, by gerwin
I did the same test again with a MS6905-Master Ver.2 that I received. The previous test was with Ver2.3. All other things remained the same.
The system ran for 4 and a half hours with the 3DMark2001SE Demo and game, again with that C3 Nehemiah at 6.0x133=800Mhz. Then after 4 and a half hours it had locked up. I am sure around 4 hours it was still running. Not bad, but not flawless.
Below the slotkets, with the jumper settings that were used for the tests.
Reply 61 of 76, by tpowell.ca
I guess the 3 pin J2 (reserved) remains a mystery. 😕
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 62 of 76, by gerwin
I will try to trace it when I have some time.
Reply 63 of 76, by feipoa
This is pretty neat - a VIA C3 on a 440BX. Has anyone tried dual CPU with the Nehemiah? I realise SMP is not supported, but VIA had originally planned to SMP support, that is, according to a spokesman I conversed pre-production.
Reply 64 of 76, by tpowell.ca
Funny. I was wondering the exact same thing yesterday. 😀
I would like to add to that, testing a dual Ezra-T configuration.
Reply 65 of 76, by tpowell.ca
Also, don't know if this is a new record but...
133.5 KiB
That's right. A 440BX motherboard with an Ezra-T at 50MHz FSB and a 3x multiplier, and stable.
Reply 66 of 76, by Tenorman
You might be the first one to take a screenshot of it, but not a new record because I've done this before too. 😀
Make sure to add L1D, L2D, ICD, and BPD on top of this for way more slowdown.
[Compaq Presario 633 | DOS 6.22 / Win 3.1 | DX4 100 Overdrive | 28M RAM | SB16 CT2770A | SPEA Media FX (Soundscape S2000) ]
[GA-6BXC R2.0 | Win98SE | Via C3 Ezra 866 | 384M RAM | TNT2 32M | Voodoo2 8M | SB32 CT3670 | Ensoniq Soundscape Opus]
Reply 67 of 76, by tpowell.ca
I did that. Was you score even lower? 7.9x was the lowest I could get without using any throttling or using BIOS settings.
Reply 69 of 76, by Tenorman
You win.
I get 8.37 running at 50 * 3 with BPD, ICD, L1D, and L2D. I could go in the BIOS and start messing with things like RAM timings, but it probably isn't worth the effort.
I also posted my score at 1.0 Ghz for comparison. Quite the range.
115.48 KiB
139.98 KiB
Reply 70 of 76, by tpowell.ca
Tenorman wrote:
You win. […]
You win.
Interesting. Considering we're using the same cpu settings, that means your board/BIOS settings combo are more optimized than mine (for top speed).
I'm using CL2 PC133 RAM with optimized defaults, precharge control enabled, delayed transaction enabled.
I wonder if having less RAM might have a positive effect on cache hit accuracy on these CPUs with so little L1/L2 cache.
Reply 72 of 76, by tpowell.ca
infiniteclouds wrote:
Guys, L1D+BPD gives you a slower speed than using all four L1D+L2D+BPD+ICD - that is what I used with my 50*3 to get 7.02.
So RAM size has no effect on SpeedSys CPU scores, but infiniteclouds is right. L1D+BPD is slower than L1D+L2D+BPD+ICD.
Very odd indeed.
And at 994MHz, my score is 520.08 making it basically the same as Tenorman's.
Reply 73 of 76, by tpowell.ca
Tenorman, what BIOS version are you using?
Reply 74 of 76, by Tenorman
I am using the Powerleap BIOS from the driver pack on Vogons Drivers:
5)powleap.bin
Source: PowerLeap Tualatin CPU adapter, by esupport.com 'the BIOS experts'
Package: Powerleap_mr_6bxc_beta
It looks like you are using the same one, judging from the date and "Award v6.00PG".
Using only L1D+BPD, I get 8.16 instead of 8.37. Not a huge difference, but it is indeed slower.
These are my RAM settings. I have not tweaked them manually. I do see that I have Precharge Control disabled and Delayed Transaction disabled.
202.21 KiB
Reply 75 of 76, by tpowell.ca
That's really odd.
Your BIOS settings for CAS latency don't make sense. CAS latency should be either 2 or 3 for SDRAM.
Also, SpeedSys in your screenshots is able to identify your external clock. That line is missing from my SpeedSys results.
Reply 76 of 76, by Tenorman
Agreed that this is odd. Maybe I will try manually configuring it sometime and see what happens. Either that or reloading the defaults. It seems to work though so I'm not too worried about it.
I will double-check that we are using the same version of SpeedSys later. I am running it in MS-DOS mode, but EMM386 is loaded, so that could also be a difference.
