feipoa wrote on 2021-08-02, 02:53:
I think the LS-486E rev.D's fancy status stemmed from ph4nt0m's posts, at least it started to interest me after his tests at 66 MHz. Which other motherboard works stable at 66 MHz besides the MB-8433UUD? Generally, SiS496 based boards have slightly faster memory throughput compared to UM8881 based ones, so I figured the LS-486E rev.D with PS/2, EDO, and an IBM 5x86c-133/2x might yield slightly faster results.
I see.
Well, 200MHz is actually much easier to do than 180. That is for 486 CPU at least.
4x50 and is done. The system runs within specifications and at tightest BIOS timings (assuming decent motherboard).
Performance is better than 3x66 which runs way out of spec and requires inflated wait states.
But 200MHz is kind of a toy, because of the 12V Peltier and related icing. Still good for bragging rights.
Real action is at 3x60 with 5V Peltier - can be a real, long term-stable, computer.
But i think you are after Cyrix 586 @ 2x66, right ?
I have since been able to get the PS/2 working. For me, and AMIKEY-2 didn't work at all for the mouse, but a HT6542B and VT82C42N worked fine. It is a bit difficult to accept the CMOS year though. It will ultimately cycle through 1996, 1997, 1998, 1999, 1996, 1997, etc. You get those 4 years only. Plus you loose the onboard floppy. The other issue is PCI slot 1 is right infront of the CPU socket, so your choice of cards are very limited.
Good to hear you sorted out the PS2 thing. Expect a call if i need to do something like that in the future.
Cannot remember when was the last time i used floppy, or even Gotek. The presence of CF card eliminates the need for it.
Worst case - one can switch for a moment to 4x40 if floppy is a must have for some operation. But yeah, not great.
It is curious that you were able to run faster SRAM timings with 512K single-banked. These ALi PCI 486 boards were weird. Is 66 MHz stable?
This board can do only 25, 33, 40 and 50 - verified very carefully.
There is a longer story here ...
I also didn't expect single banked L2 cache to handle such tight timings.
It will be really interesting when i give the mobo a proper 200MHz spin at some point later and see if 1024Kb double banked is possible and what the perf is.
Are your ISSI 10 and 12 ns SRAM modules the Chinese fake ones?
I have several different types of 24/28 pin ISSI chips. Some of them are 10ns and 12ns ones.
People call them fake, but they for sure tick better than most 15ns ones.
The difference is obvious in systems on the edge.
🤣 @ speedsys w/RAM faster than L2. I think either this chipset or these boards were made to work well without L2.
Yeah, it is weird. Cracked me up.
@BitWrangler
VLB running at 66MHz will be a tall mountain to climb, but 4x50 is usually ok. Maybe try that first.
Btw, how do you like this mobo ?
Can it actually to 66 FSB ?
Also, did you try the 386 hardware path of the UMC based board in the upper middle ? Looks interesting.
