First post, by mechcentric
The only VGA versions I can find have sound built in??? It sounds kind of like MT-32 but there's no setup exe or menu????? How do I get the original version to run on real DOS with REAL MT-32??????????
mechcentric
AMD 386sx-40/33/25/20, 4MB SDR, CT2230
Intel 486dx2-66, ATI Mach32/64 VLB 1+1MB, 16MB SDR , CT2290
Pentium MMX 166, ATI Rage II + DVD, Voodoo1, YMF718-s
Pentium III 850, Voodoo3 3500, 2x256MB SDR, Aureal Vortex 2 (MX300), 10/100 LAN
Dell P991
Reply 1 of 3, by tpowell.ca
Have you checked for command-line options?
There should be a readme.txt or something like it describing the options. I believe "r" after monkey.exe gives you ROLAND MT-32 midi, and "a" gives you adlib/soundblaster music.
  • Merlin: MS-4144, AMD5x86-160, 32MB, 16GB CF, ZIP100, ESS688, GUS, S3 VirgeGX 2MB, HardMPU
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, GUS 16MB, Voodoo3-3k
    Einstein: P8P400, P4-3GHz HT, 1.5GB, Quadro4 980XGL, Live!
Reply 2 of 3, by root42
I think Lucasfilm games starting with Indy 3 give options when typing the game exe followed by a question mark:
monkey ?
This should show you all possible command line options
YouTube and Bonus
Reply 3 of 3, by mechcentric
FIXED
i had to add the patch disk to the install directory and run with "r" modifier
bc pirate say "r" 🤣
mechcentric
Dell P991
